Having trouble with complex quadratic equations
The discussion revolves around solving a complex quadratic equation involving complex numbers. Participants explore the application of the quadratic formula to find a variable when given specific values for a complex number.
  • Homework-related
  • Jeff presents a complex quadratic equation and expresses uncertainty about solving for A given specific values for Q and Bi.
  • Jeff's attempt to apply the quadratic formula leads to a result that does not match his known value for A, prompting him to seek help.
  • Hurky suggests that Jeff made errors in substituting values into the quadratic formula.
  • Another participant points out that Jeff may have confused the variables in the equation.
  • Jeff acknowledges a mistake in his substitutions and expresses gratitude for the clarification, indicating he now understands the correct approach.
The discussion shows some disagreement regarding the initial interpretation of the problem and the substitutions made in the quadratic formula. However, Jeff ultimately agrees with the corrections pointed out by Hurky.
There are unresolved aspects regarding the specific substitutions and the interpretation of the variables in the quadratic equation, which may affect the understanding of the problem.
Readers interested in complex numbers, quadratic equations, and mathematical problem-solving may find this discussion beneficial.
Jeff Cook
All,
I am not sure how to handle this situation with complex numbers. Can you help?
Q = A^2 + ABi
Where Q is a complex number.
Can we not solve for A if we know Q and Bi using a quadratic equation?
0 = A^2 + ABi + -Q
Let...
Q = 455
Bi = -22
And in this case I do know that A = 35. However...
When,
a = 1
b = -22
c = -455
Solving...
A = ( -1 +/- Sqrt { 1 - ( 4 * -22 * -455 )}) / 2
I do not get A = 35. Any idea why and what I may be doing wrong?
Thanks,
Jeff
You messed up while substituting values into the quadratic formula.
Show...
Hurky,
Could you show me what you mean? Where did I mess up?
J
You have confused what the problem is. You are using A in place of X, then you turn around and act like it is something else.
Jeff Cook said:
Hurky,
J
There are 5 places in the quadratic formula where you need to substitute a number. You got three of them wrong. You know the quadratic formula, right? The solutions to
ax² + bx + c = 0
are
[tex]\frac{-b \pm \sqrt{b^2 - 4ac}}{2a},[/tex]
right? Just double check your work!
I'm quite sure he did not make that mistake.
Oops...
Hurky,
Okay, I was placing a in place of b in the quadratic equation. Stupid mistake. Thanks greatly. Now I get the correct answer.
Jeff
