| Thread Closed |
The same derivative here give different solutions if you solve it in different ways |
Share Thread | Thread Tools |
| Jan4-07, 06:50 AM | #1 |
1) In the middle of a max min problem, i set the function that gave me the area that the problem requested. it's:
[tex]A=\frac{\sqrt{2x-x^2}*(2x-1)}{2}[/tex] (but i can omit division by 2) [tex]A'=2\sqrt{2x-x^2}+\frac{(2-2x)(2x-1)}{2\sqrt{2x-x^2}}[/tex] [tex]A'=\frac{8x-4x^2-4x^2+2x+4x-2}{2\sqrt{2x-x^2}}[/tex] putting the derivative = 0, [tex]8x^2-14x+2=0[/tex], which gives the right result, [tex]x_\textrm{1,2}=\frac{7\pm \sqrt{33}}{8}[/tex]. 2) Now doing the square of the distances, i get: [tex]A=(2x-x^2)(2x-1)^2=8x^3+2x-8x^2-4x^4-x^2+4x^3[/tex] A'=0: [tex]8x^3-18x^2+9x-2=0[/tex] (not solvable with ruffini), should be equal to the result of the first derivative, [tex]x_\textrm{1,2}=\frac{7\pm \sqrt{33}}{8}[/tex]. and in fact if i put the solutions of this first in the other, they work. but there is a third solution in the second, right? and however the equations are not the same, this worried me a lot on the problems i would get with square root of distances instead of pure distances. can anyone tell me why i don't get the same equation? thanks. |
| Jan4-07, 06:56 AM | #2 |
I believe you have neglected to differentiate your expression for A in the second part.
| Jan4-07, 07:04 AM | #3 |
| Jan4-07, 07:15 AM | #4 |
| Jan4-07, 07:17 AM | #5 |
I haven't checked but it is quite possible that the third solution to the cubic equation does not satisfy the original equation (with the square root) because it makes the root imaginary.
| Jan4-07, 07:23 AM | #6 |
Mentor
[tex]8x^3-18x^2+9x-1=(2x-1)(4x^2-7x+1)=0[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: The same derivative here give different solutions if you solve it in different ways
| Solve plz give me some help | Introductory Physics Homework | 5 | ||
| Any other ways to solve? | Introductory Physics Homework | 15 | ||
| Solve this and I'll give you whatever you want | Introductory Physics Homework | 1 | ||
| Illogic-ways to sucker people/ways to avoid being a sucker | General Discussion | 1 | ||
