Challenging Mechanics Questions: Help Needed!
  • Thread starter Thread starter Auron87
    Mechanics
The discussion revolves around mechanics problems related to the Saturn V rocket and a railway truck with falling sand. Participants are exploring concepts of thrust, momentum, and forces in dynamic systems.
  • Mixed
  • The original poster attempts to calculate thrust and resultant forces for the rocket and the additional horizontal force for the railway truck. Some participants discuss the application of formulas related to mass flow rates and forces, while others question the necessity of time in the calculations.
Participants are actively engaging with the problems, with some providing insights into the formulas and variables involved. There is a recognition of the need to consider gravity in the rocket problem, and the discussion is exploring how to apply the relevant equations without reaching a consensus on the methods.
There is mention of the original poster's frustration with the problems, indicating a potential lack of clarity or understanding in the application of the concepts. The discussion includes variables that may not be fully defined, such as time in relation to the thrust calculations.
Auron87
We have been given a set of questions to do. Most of these I have managed fairly easily but there are some which I am really stuck on and am getting quite annoyed with now as I have been working at them for ages! Help on any of these would be really appreciated:
The Saturn V rocket which launched the Apollo space missions had the following specifications:
mass at lift-off = 3.0 x 10^6 kg
velocity of exhaust gases = 1.0 x 10^4 m/s
initial rate of fuel consumption at lift-off = 3.0 x 10^3 kg/s
1.(a) Calculate:
(i) the force (thrust) produced at lift-off
(ii) the resultant force acting on the rocket at lift-off
2.(a) An empty railway truck of mass 10000kg is traveling horizontally at a speed of 0.5m/s. (had to calculated the momentum and kinetic energy - not sure if this will help with the bit I am stuck with!)
Sand falls vertically into the truck at a constant rate of 40kg/s. Calculate the additional horizonal force which must be applied to the truck if it is to maintain a steady speed of 0.5m/s.
Thanks for anyones help - I can usually manage these kind of questions but I'm really stuck for some reason!
1.(a) Calculate:
[tex]Ft = mv[/tex]
Derive both sides
[tex]F = (\frac{dm}{dt})(v)[/tex]
I think this means to include gravity. It should be whatever you got from part (i) - gravity.
[tex]Ft = mv[/tex]
Derive both sides
I've not met that formula before but I do understand where its from but how can you use it because you don't know time or is it necessary to work out the time or something??
dm/dt is a variable, not a division of 2 or 4 variables :wink:
In the first question, dm/dt is 3.0 x 10^3 kg/s
In the second question, dm/dt is 40kg/s
  • · Replies 20 ·
