What is the magnitue of the average Force from the wall stopping it?
The original poster presents two questions involving physics problems: one related to the average force exerted by a wall on a bullet and another concerning the speed of a girl sliding down a playground slide with friction. The context includes concepts from kinematics and energy conservation.
  • Mixed
  • Participants discuss the application of kinematic equations and the work-energy theorem. The original poster questions their calculations and the assumptions made regarding constant acceleration. Others suggest checking units and reconsidering the approach to the second problem involving friction and energy changes.
The discussion is ongoing, with participants providing guidance on checking calculations and units. There are multiple interpretations of how to approach the problems, particularly regarding the assumptions of constant acceleration and the setup of energy equations.
There are concerns about unit conversions and the treatment of forces, such as friction and normal force, in the context of the second problem. The original poster expresses uncertainty about their calculations and the relationships between variables.
nemzy
What am I doing wrong?
Question:
A 41 g bullet, with horizontal velocity of 496 m/s, stops 13cm within a soid wall. What is the magnitue of the average Force from the wall stopping it?
This is how i tried to solve it
Vi = 496, Vf=0, and Xf-Xi=.13m
So Vf^2=Vi^2+2a(Xf-Xi)
Which = 0 = 246016+2a(.13)
solve for acceleration you get -946215...
F=m(a)...so i did (-946215)(41) which does not equal the answer? Am i doing anything wrong?
2nd Question:
A girl whose weight is 264 N slides down a 5.8 playground slide that makes an angle of 20degree with the horizontal. The coefficient of kinetic friction is 0.10. If she starts at the top with a speed of 0.457 m/s, what is her speed at the bottom?
This is how i tried to slove it
W= change in U + change in K + change in Thermal
Thermal = 143.98 (i won't show my calculations cause i am 100% sure this is righ)
so..
F(d)= -mgh +(1/2)mv^2 - (1.2)m(.457^2) +143.89
After you plug in all your variables, you have two unkowns,velocity and W.. Provided i did the setup right, how do i figure out the velocity of i don't know the magnitude of her force?
#1: Check your units (41g = .041 kg)
#2. Work-energy theorem:
[tex]\Delta K + \Delta U = W_{nc}[/tex]
[tex]K_i = \frac{mv_i^2}{2}[/tex]
[tex]K_f = \frac{mv_f^2}{2}[/tex]
[tex]U_f = 0[/tex] (your choice of datum)
[tex]U_i = mg(d\sin \theta)[/tex]
[tex]W_{nc} = -fd[/tex]
where
d = 5.8 m; length of the slide
[tex]\theta = 20^\circ[/tex]; angle of slide
f = μ N; friction force
μ = 0.10; coefficient of friction
[tex]N = mg\cos\theta[/tex]; normal force
inst the worky - energy theorem change in K + change in U + change in Thermal (since there is friction?) = W
OK,
How are you computing the "change in thermal energy" and what is your value for W?
Originally posted by nemzy
Question:
A 41 g bullet, ...
... Vf^2=Vi^2+2a(Xf-Xi)
How do you know that the acceleration is constant?
2nd Question:
A girl whose weight is ...
I wouldn't do it that way. I would use the kinematic equation that you are trying to use for the first question.
  • · Replies 22 ·
