How Do You Calculate the Internal Resistance and EMF of a Solar Cell?
  • Thread starter Thread starter incubusguy88
    Circuits Homework
The internal resistance of the solar cell is calculated to be 250 Ω, while the electromotive force (emf) is determined to be 0.20 V. The analysis is based on two potential differences (0.10 V and 0.15 V) across resistors of 600 Ω and 1150 Ω, respectively. The efficiency of the solar cell in converting light energy to thermal energy is derived from the power delivered to the load resistor, which is calculated using the area of the cell (2.0 cm²) and the energy rate (2.0 mW/cm²).
  • Understanding of Ohm's Law and circuit analysis
  • Familiarity with electromotive force (emf) concepts
  • Knowledge of efficiency calculations in electrical systems
  • Basic principles of solar cell operation
  • Study the derivation of Ohm's Law in DC circuits
  • Learn about solar cell efficiency calculations
  • Explore the impact of internal resistance on circuit performance
  • Investigate different methods for measuring emf in solar cells
Electrical engineers, renewable energy researchers, and students studying solar energy systems will benefit from this discussion on calculating internal resistance and emf in solar cells.
incubusguy88
Someone please help me out with this problem, I can solve for the current but from there i get stuck...
A solar cell generates a potential difference of 0.10 V when a 600 resistor is connected across it, and a potential difference of 0.15 V when a 1150 resistor is substituted. What are
(a) the internal resistance and
(b) the emf of the solar cell?
(c) The area of the cell is 2.0 cm2, and the rate per unit area at which it receives energy from light is 2.0 mW/cm2. What is the efficiency of the cell for converting the light energy to thermal energy in the 1150 external resistor?
Originally posted by incubusguy88
What are
The best thing to do is solve these two simultaneously (2 eqs. and 2 unkwns.). Can you please describe how you are modelling your circuit?
You need to know the definition of efficiency, and how to find the power delivered to the load resistor. Do you know these two things?
Sure, I can help you with this DC circuits problem. First, let's start by writing out the given information:
Potential difference (V) = 0.10 V and 0.15 V
Resistance (R) = 600 Ω and 1150 Ω
Area (A) = 2.0 cm2
Rate of energy (P) = 2.0 mW/cm2
(a) To solve for the internal resistance (r) of the solar cell, we can use the formula V = EMF - Ir, where V is the potential difference, EMF is the electromotive force (emf) of the solar cell, and I is the current. We know the potential differences for both resistors, so we can set up two equations:
0.10 V = EMF - (I)(600 Ω)
0.15 V = EMF - (I)(1150 Ω)
We can then solve for I in both equations and set them equal to each other to eliminate I:
0.10 V = EMF - (0.10 V/600 Ω)(600 Ω)
0.15 V = EMF - (0.15 V/1150 Ω)(1150 Ω)
0.10 V/600 Ω = 0.15 V/1150 Ω
0.0001667 A = 0.0001304 A
EMF = 0.104 V
Now, we can plug in this value for EMF into either equation to solve for I:
0.10 V = 0.104 V - (I)(600 Ω)
0.0004 A = I
Finally, we can plug in this value for I into the formula for internal resistance:
r = (0.10 V)/(0.0004 A)
r = 250 Ω
So, the internal resistance of the solar cell is 250 Ω.
(b) To solve for the emf of the solar cell, we can simply plug in the values we found for EMF and internal resistance into the formula:
EMF = V + Ir
EMF = 0.10 V + (0.0004 A)(250 Ω)
EMF = 0.20 V
So, the emf of the solar cell is 0.20 V.
(c) To find the efficiency of the solar cell, we can use the
  • · Replies 20 ·
  • · Replies 34 ·
