If water is exposed to high voltage, it will ionize.
The discussion centers around the ionization of water when exposed to high voltage, specifically exploring the minimum voltage required for this process and the implications of using electrical devices submerged in water. Participants examine the energy needed to remove electrons from water molecules and the practical scenarios involving heating elements in everyday appliances.
  • Experimental/applied
  • Some participants propose that water can ionize at around 0.83V, referencing ionization potentials for hydrogen and oxygen molecules.
  • Others question whether the voltage required scales with the number of water molecules, suggesting that millions of molecules would require millions of volts.
  • A participant clarifies that electrolysis of water does not require millions of volts, noting that typical electrolysis occurs around 1 to 2 volts, depending on the setup.
  • Concerns are raised about the practical implications of submerged electrical devices, questioning whether a heating element could ionize surrounding water and if the current is sufficient for this process.
  • Another participant mentions that immersion heaters typically have insulating coatings, which may prevent ionization of water in practical applications.
Participants express differing views on the voltage required for ionization, with some asserting lower voltages are sufficient while others suggest higher voltages may be needed depending on the context. The discussion remains unresolved regarding the exact conditions under which water ionizes in practical scenarios.
There are limitations in the discussion regarding the assumptions made about the state of water (liquid vs. gas) and the specific conditions under which ionization occurs, including the effects of different electrodes and the nature of the electrical circuit.
This discussion may be of interest to those studying electrochemistry, electrical engineering, or anyone involved in the design and use of electrical appliances in wet environments.
sunchips
if water is exposed to high voltage, it will ionize. What is the minimum voltage needed for that to happen? Thanks!
What is the energy required to remove an electron from a hydrogen or oxygen molecule?
AM
AM
This will only give you an estimate of the ionization potential for H2O(gas). In the liquid state, the number is much lower, due to several effects that are not easy to calculate (you can think of these as described by a local dielectric constant). I believe the number for water is about 1 volt.
EDIT: Yup, the standard reduction potential tables tell me it's 0.83V
so, say a circuit is submerged in the water. The circuit requires only a 0.83V to ionize the surrounding waters?!? Wow! I though it wouold be much higher than that!
Wasn't that for 1 molecule?
So if you had millions of molecules it'd take millions of volts right?
sunchips said:
so, say a circuit is submerged in the water. The circuit requires only a 0.83V to ionize the surrounding waters?!? Wow! I though it would be much higher than that!
Multiply that by the number of coulombs of charge to get the energy. So the energy to remove an electon from a water molecule in the liquid state is .83eV or .83 x 1.6e-19 C = 1.3e-19 Joules.
AM
so is this true? Thanks!
No, it's not. It does not take 2 million volts to produce hydrogen from the electrolysis of water (it takes about 2 volts). The Daniell (Cu|CuSO4||ZnSO4|Zn Galvanic) cell produces an EMF of about 1.1V (not millions, billions or an Avogadro number of volts).
The real number will be about 1 or 2V. There will be a deviation from the ideal ionization potential, in a real electrolytic cell, that depends on the electrodes used. An ideal, inert electrode will get you closest to the ideal number. Any other electrode will require an overvoltage to produce the same current as the ideal cell.
Heard of anyone that killed their cell phone by dropping it in water? Typical phone batteries run at somwhere between 3V and 4V - easily enough to ionize a path through water (if the phone case isn't watertight) and make a short.
I'm sorry..I think I didn't explain my situation well enough. I am asking, in terms of say...
suppose we have a heating element submerged in water. (e.g. a coffee maker, or amny other possible everyday things). When the current is passed through the nichrome heating element, will the current ionize the surrounding waters? is it powerful enough?
Sorry if I didnt explain myself well before, and thanks for all your help!
To the best of my knowledge, all immersion heaters have an electrically insulating (but thermally conductive) coating over the nichrome element. I'd expect the outer case to be grounded.
  • · Replies 25 ·
  • · Replies 22 ·
