How do you calculate current in a changed parallel circuit?
The discussion centers on calculating current in a modified parallel circuit. The original circuit had four branches with equal resistance and a voltage of 24V. When one branch is removed, the circuit effectively becomes a three-branch parallel circuit. The current must be recalculated based on the new configuration, taking into account the unchanged voltage and the modified resistance.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of parallel circuit configurations
  • Familiarity with calculating total resistance in parallel circuits
  • Basic algebra for manipulating equations
  • Study the calculation of total resistance in parallel circuits with varying branch counts
  • Learn how to apply Ohm's Law in practical circuit scenarios
  • Explore the effects of removing components in parallel circuits on overall current
  • Investigate circuit simulation tools to visualize changes in current and resistance
Electronics students, electrical engineers, and hobbyists interested in circuit analysis and current calculations in parallel circuits.
bobtheubs
http://feat.putfile.com/profilepics/main/4/bobthebus-1313021205.jpg
Well this is my question, its not really homework or anything. I am just curious as to how you would do this. I was thinking that it would change at all. Since in a parallel circuit all the currents add up to the same number. So wouldn't you just divide 24 by 4, then minus 6 from the total I. Then times that by 3 and there you go. Thanks.
Could you write out the question please? I can't read that!
Your voltage didn't change, but your resistance changed, so the current has to change.
The picture is hard to read, but I take it all the resistances are equal and the circuit is broken at P?
If so, you now have a parallel circuit with three branches instead of four. If you work both equations using R and simplify, the difference between them should be pretty obvious.
  • · Replies 42 ·
  • · Replies 30 ·
