How to Determine Transformation Parameters for Triangles in Geometry?
The discussion revolves around determining transformation parameters for triangles in geometry, specifically focusing on rotations, enlargements, shears, and reflections. Participants are exploring how to identify centers of rotation and enlargement, as well as understanding the effects of transformations on triangle coordinates.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss methods for finding the center of rotation by analyzing the movement of triangle vertices and drawing secants. Questions arise about the clarity of these methods and the need for visual aids. The concept of enlargements is examined, with inquiries about how to determine the center when lines do not intersect. Shear transformations and reflections are also addressed, with participants seeking clarification on their properties and implications.
Guidance has been offered regarding the process of finding the center of rotation and enlargement, with some participants suggesting the use of graphical methods. There is an ongoing exploration of the implications of different angles of rotation and the conditions under which the methods apply. Multiple interpretations of the transformation processes are being discussed, indicating a productive exchange of ideas.
Participants are working within the constraints of homework rules, seeking to understand the underlying principles of geometric transformations without direct solutions. There are mentions of potential confusion regarding the relationships between original and transformed points, as well as the necessity of visual representation in understanding these concepts.
Johnny Leong
(a) If a triangle ABC with coordiantes A(2,7), B(2,9) and C(6,7) has a rotation and maps to triangle PQR with coordinates P(6,5), Q(8,5) and R(6,1), what is the centre of rotation? I want to ask in general, what's the way to find the answer?
(b) An enlargement maps the triangle ABC with coordiantes A(2,7), B(2,9) and C(6,7) onto triangle XYZ with coordiantes X(12,12), Y(12,13) and Z(14,12). How to find the centre of enlargement? And this question, the enlargment scale factor is 1/2, right?
(c) A shear maps triangle ABC with coordiantes A(2,7), B(2,9) and C(6,7) onto triangle LMN with coordinates L(2,10), M(2,12) and N(6,16). How to find the shear factor? And is this transformation first with a reflection and then a shear?
(d) A triangle ABC wiht coordinates A(1,1), B(0,2) and C(3,1) is reflected in the line y=-x. How to find the matrix which represents the reflection?
Please help me for these. I need to have examples of this to solve other problems.
If you draw the change in direction for one of the points, you are drawing a secant across the arc that the point actually moved across. The only point where a radius can be drawn perpendicular to the secant as well as the arc is at the midpoint of the secant. Find the midpoint of the secant then draw a line perpendicular to it. This represents the radius for that point.
Do that same process for the other 2 points. Where all 3 radii meet is the centre of rotation.
I don't quite understand how to draw the secant and the arc for the change in direction for one of the points. Would you please explain more or have a rough graph for me? Thank you for your attention!
Sorry if my grammar and wording is hard to understand, I'm just a little tired right now.
Here is a picture of what I mean.
http://myfiles.dyndns.org/pictures/secant.jpg
Draw a line showing the change in position for one of the points on the triangle. Find the midpoint of that change. From the midpoint, draw a perpendicular line.
This 1 line alone will not show you exactly where the centre is but it will point you in the right direction. You will find the centre of rotation by doing this same thing to a different point on the triant then finding where those perpendicular lines drawn intersect.
In my first post I said you need to intersect 3 lines but that's not exactly true now that I think about it. You only need to intersect 2 lines.
You don't really need to "draw" the secant and arc. ShawnD's point was that a rotation moves points in circles. The original point and ending point are on a circle: the secant is simply the line segment connecting them. Knowing the coordinates you can find the midpoint of that line and its slope. The slope of the perpendicular is -1/slope of the line so you can write down its equation. Take another "beginning" point and its "end" point and do the same. The place where they intersect is the center of rotation.
By the way: saying that the rotation takes "the triangle with vertices A B C" into "the triangle with vertices P Q R" does NOT necessarily mean that it maps A into P, B into Q, and C into R. You might want to mark the points on a graph to see which point goes to which.
b) is actually easier: an "enlargement" moves every point out on a "radius"- a line through the center of enlargement. Write the equations of the line through each "beginning" and "ending" point. Solve two of those simultaneous equations for the (x,y) center and check in the third to see that all three line intersect at the same point.
For c) Draw a picture! (Actually you should do that for all of these.) It should be obvious that there is no reflection. Notice that A and B lie on a vertical line A and C lie on a horizontal line. P and Q still lie on a vertical line but P and R do not! What angle is that?
d) Simplest problem of all: Reflecting in the y= -x, (1, 0) changes into what point? (0,1) changes into what point? (DRAW A PICTURE IF YOU ARE NOT SURE!) What matrix does that? Write out a matrix [a b] [1] [0]
[c d] and apply it to [0] and [1].
(I chose (1,0) and (0,1) because they make answering that last question very easy.)
Thank you very much for your nice reply, ShawnD. I have got it. But if the rotation is not 90 degrees, can the same method be applied to find the centre of rotation?
If there's no intersection for the lines joining the points of the original triangle and the corresponding points of the mapped triangle, how can find the centre of enlargement?
