Aquarium Calculus: Calculating Water Changes
  • Thread starter Thread starter Jean-Louis
    Aquarium Calculus
The discussion revolves around calculating water changes in an aquarium, specifically focusing on determining the volume of water to replace daily in order to achieve a desired percentage of water replacement over a set period. The subject area includes calculus and algebraic reasoning related to exponential decay and volume calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore various formulas for calculating daily water changes based on tank volume and desired replacement percentage over time. There are attempts to derive general formulas applicable to different tank sizes and timeframes. Some participants question the assumptions behind the calculations, particularly regarding the nature of water replacement and its relation to exponential decay.
The discussion is ongoing, with participants providing different perspectives on the problem. Some have offered potential formulas and calculations, while others emphasize the importance of understanding the underlying concepts rather than simply providing solutions. There is a mix of interpretations regarding whether this is a homework question, with some participants suggesting that it is more of a practical inquiry.
There is a debate about whether the original poster's inquiry constitutes a homework question, with some participants asserting that it is not. Additionally, there are discussions about the need for the original poster to demonstrate their understanding and attempts before receiving further guidance.
Jean-Louis
How to devise a usefull formula for aquarium water changes.
I have a 50g tank (not including substrate and animals). I want to do daily water changes so that at the end of 6 months I will have replaced 95% of the water present at the beginning of the water change regimen. I want to replace the same volume every day.
1. What volume should I replace each day?
2. What is a general formula I could use for larger or smaller tanks? Or for changing the amount of time over which I replace the 95%. (So I could use it if I decide to set up a X
gallon tank and have my water 'turn over' period every Y months.)
3. What is a general formula I could use that contains the variables from (2) but also allows me to change the periodicity (say I get lazy and only want to do weekly water changes.)
I'd wait for someone not as rusty to confirm this, but
Gallons of Old at time T = V[initial]exp-(VT/V[initial])
where V=constant removal rate per unit of time, V[iniital]=initial volume
units of removal rate have to equal units of T, e.g. per day, per second
so roughly .83 gallons/per day need to be removed over 180 days to have 5% or 2.5 gallons of old water remaining
This is incorrect as if you change the water 180 times and remove 0.83 gallons each time you get (0.83 gallons/day)*(180 days) = 149.4 gallons
Let your volume be X and months be Y (as you requested), then the amount of water you would change per day would be 0.95X/(Y*30) = dv/dt = 0.005277V gallons/day. So, for your 50g tank, you would change 0.264 gallons / day if you want to for 6 months.
Let the 30 become U, where that is the how often you wish to change the water.
so: Y=period (one week, two weeks, 6 months) where you change out the desired % of water.
U = equal division of period (changing water everyday, once a week)
Just to check units...
0.95X gallons / ([Y time][U timeunits/time] = gallons / timeunits
Also, you can change the 0.95 to whatever % of water you wish to change.
My explanation may seem complicated, let me know if you need clarificationSo in short, use this
PX/(YU) = gallons/time
P=overall percentage you want to change out over the period Y
X=Volume of tank
Y=period
U=equal partition of interval that corresponds to how many times you change the water per interval
chemhelper. We do not give out full solutions to homework questions, but are here to guide students to the correct answer. Also, please note that, until the original poster has shown his/her working, and attempts at the question, we cannot give any help. See the guidelines https://www.physicsforums.com/showthread.php?t=94379
No evidence that this is a homework question. The fact that someone moved it to the homework section isn't evidence either.
Chemhelper: Your solution is simplistic and wrong. You fail to take into account that the percentage of old water in the tank diminishes with time as it is replaced with new water...he's not emptying the tank, this is an exponential decayh
From past experience, this sounds like a homework question. Also, the fact that a mentor has moved it to the homework forum, shows that they agree with me!
Whether it is homework or not, the way to help a person learn, is not to solve the problem for them, and not to tell them what to do before they have shown to us that they have thought about the problem.
Sorry. I stand corrected.Jean-Louis may come and correct me on this (in which case I am sorry for explaining how to do it), but I do not believe it is his desire or care to learn how to derive formulas; he states that he has an aquarium that he wants to apply this to, so why make him try to learn Calculus? Perhaps he has no idea about how to derive the formula he needs. When I posted, it was in the main forum. So unless you have evidence showing that he is a student, don't criticize me when I was following the rules.
Thanks for your feedback. This is not homework. I have an aquarium, and I wanted a mathematical approach. I think I founded. I was told that this not a calculus problem, since the water is not continuously changing. So the approach is algebraic.
Sorry if I caused any inconvenience.
(if you are interested I could post the algebraic solution.)
Well, if you're taking water out of the aquarium at some modest rate per period and replacing it with new water, and want to have a certain percentage of "original" water remaining after a certain amount of time, it really is a calculus problem.
The 0.83 gals/day=10.97% per week. Coincidentally, this calculator http://www.angelfish.net/DripSystemcalc.php
validates exactly the equation above if you plug in the 50 gals and 0.83 gal/day rate
I thought this was a Differential Equations kind of Calc. I couldn't do one now but I remember these types of questions in DE.
  • · Replies 56 ·
