Register to reply
Finding the concentration of a gas (thermodynamics)
by raul_l
Tags: concentration, thermodynamics
Share this thread:
raul_l
#1
Jan16-07, 09:29 AM
P: 105
Hi.
The root mean square velocity of oxygen molecules is 480m/s while the pressure is 20kPa.
What is the concentration (particles/volume) of oxygen?
2. Relevant equations
PV=nRT
[tex] E_{kin}=\frac{m \overline{v}^2}{2}=\frac{3}{2}kT [/tex]
3. The attempt at a solution
[tex] m \overline{v}^2=3kT \Rightarrow T= \frac{m \overline{v}^2}{3k} [/tex]
[tex] PV=nR \frac{m \overline{v}^2}{3k} \Rightarrow n=\frac{3kPV}{Rm \overline{v}^2} [/tex] where [tex] m=2 \times 16 \times 1.66 \times 10^{-27} kg [/tex]
I set V=1m^3 and get n=8.137mol and therefore [tex] \frac{n \times n_{a}}{V}=4.899 m^{-3} [/tex] where [tex] n_{a}=6.02 \times 10^{23} [/tex]
Is this correct? I'm sure there's a simpler way to do this.
Phys.Org News Partner Science news on Phys.org
'Office life' of bacteria may be their weak spot
Lunar explorers will walk at higher speeds than thought
Philips introduces BlueTouch, PulseRelief control for pain relief
GCT
#2
Jan16-07, 07:54 PM
Sci Advisor
HW Helper
GCT's Avatar
P: 1,769
Note that the mass refers to an individual oxygen molecule (from what I recall at the moment), (16 grams of Oxygen/mole of Oxygen)(1 mole/6.022 x 10^23 atoms)(1 kilogram/1000 grams)(2 atoms of Oxygen/1 diatomic molecule)=____.......the setup should be solved for n/V, this means that you need to incorporate a particular value of R, choose from the list on the page that can be linked to through the below text so that the final units for n/V is respect to moles/liter.
http://en.wikipedia.org/wiki/Gas_constant
raul_l
#3
Jan17-07, 04:01 AM
P: 105
Actually, since this is one of my physics class problems (not chemistry) concentration really does mean particles/volume in this case. Which means that I have chosen the right value for R, I think.
Gokul43201
#4
Jan17-07, 04:12 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
Quote Quote by raul_l View Post
You're missing a factor of 10^{24} in that final bit.
The method is perfectly correct - I haven't checked the numbers, but I believe the final number looks close enough (I happen to know that the RMS speed of oxygen molecules at room temperature is about 500m/s, and at NTP, a mole of atoms occupies about 22.4 liters, so at a fifth of an atmosphere, the concentration would be roughly 6/(5*0.0224)*10^{23} per cubic meter, which is about 10% higher than your number, but this is very rough estimate.)
As for a simpler way, I think this is as simple as it gets. Only, notice that since R=k*Na, and M=m*Na, your final expression simplifies to n=3PV/Mv^2 (in moles).
GCT
#5
Jan17-07, 07:01 PM
Sci Advisor
HW Helper
GCT's Avatar
P: 1,769
(n/v)=20 kPa(1000 Pa/1 kPa)(1.3806503 10-23 m2 kg s-2 K-1)3/[8.314472 m^3 Pa K-1 mol-1(16 grams of Oxygen/mole of Oxygen)(1 mole/6.022 x 10^23 atoms)(1 kilogram/1000 grams)(2 atoms of Oxygen/1 diatomic molecule)(480 m/s)^2]= 0.00813782909722 moles/m^3
(0.00813782909722 moles Oxygen/L)(6.022x10^23 molecules Oxygen/mole)= 4.900600682 x 10^24 molecules/m^3
So there's everything done in a perfunctory fashion for ya, I wanted to see what answer would result with the "chemist" method.
I'm going to need to see if the units cancel out exactly.......
Register to reply
Related Discussions
Finding out the concentration of an acid or base Chemistry 3
Thermodynamics-Finding Internal energy Introductory Physics Homework 1
Finding Free Electrons and Hole Concentration Engineering, Comp Sci, & Technology Homework 1
Finding the iodide ion concentration Biology, Chemistry & Other Homework 1
Chemical Equilibrium, finding concentration Chemistry 2
