How Should Time Be Entered in Circuit Power Calculations?
The discussion revolves around a circuit power calculation problem where the original poster is tasked with determining the power absorbed by a circuit element. The problem provides current and voltage as functions of time, with a specific time point of 2 milliseconds at which the power needs to be evaluated.
  • The original poster questions whether to use 2 milliseconds directly or convert it to seconds for the calculations. Participants discuss the importance of using standard SI units and the implications of time being part of trigonometric function arguments.
Participants have provided insights regarding the use of seconds as the standard unit for time in calculations. There is an exploration of the relationship between time and the arguments of trigonometric functions, with some participants clarifying that the argument of a trig function is conventionally in radians.
There is an ongoing debate about the interpretation of time units in the context of trigonometric functions, particularly regarding the conversion of milliseconds to seconds and how it affects the calculations.
student85
I have to give the power being absorbed by the circuit element. There's a picture. This is an easy problem. They give me the current flow in a function of time, the voltage is also in function of time. The time in which I require to give the power is at 2ms. The function for the current is 8 cos (1000t) mA , and the one for voltage is 4 sin (1000t) V. MY QUESTION IS: Do I insert 2 as the variable for time or do I change 2ms into seconds (.002s) and put it in the function?
Yeah I know this has almost nothing to do with circuits but I hope someone helps me. HW is due tomorrow...
P=Vi
Well, the SI standard unit of time is the second, not the millisecond, so I presume that the current and voltage are given in terms of seconds. It is possible, though unlikely, that t is in some other unit instead.
- Warren
yes, I always change everything to SI standard units. BUT, when a variable is inside the argument of a cosine o sine, what do you do? I had this same debate while doing wave function problems (sin (kx - wt)) . So what would you do?
It depends on the units chosen by the person who wrote the problem. Normally, any unit of time is expressed in seconds, but this is just a convention. Being part of the argument to a trig function makes no difference; t is conventionally in seconds.
I would use all times in seconds.
- Warren
thx chroot.
I say this about trig functions because when you have something like sin (4t). If you put say 3s into "t", then you have the sine of 12 seconds, then when you do the trig. operation, the unit seconds is eliminated, or at least that's what I think.
The angle measures 12 s (even if that doesn't make sense), but sine is not the angle but rather the side of the triangle oposing the angle 12s over the hypothenuse, so sin (12s) is no measured in seconds.
This is very weird lol, but I've been having this confusion forever.
The argument of a trig function is an angle, usually measured in radians. If you have an expression like sin(4t), where t is in seconds, then "4" is actually in units of radians per second. It's unfortunately quite common to omit the "radians per second" unit, but it's always there.
No units are "eliminated." The resulting argument (4t) is in radians.
[itex] \frac{{4\,{\text{radians}}}}<br /> {{{\text{second}}}} \cdot t\,{\text{seconds}}\,{\text{ = 4}}t{\text{ radians}}[/itex]
The number "4" in your example is sometimes even called an "angular frequency," since it has units of angle per unit time, and is often represented in variable form by the greek letter [itex]\omega[/itex]. This is the greek letter conventionally used to describe angular frequencies, which you called "w" in post #3.
- Warren
\[/b]
The t in 1000t should be in seconds.
Thanks guys.
I'll receive my homework back in a couple of days, should be right...
  • · Replies 16 ·
