How close will the two ships get?
  • Thread starter Thread starter thomasrules
The problem involves two ships, Ship A and Ship B, with Ship A sailing due east at 8 km/h and Ship B sailing due north at 6 km/h. Initially, Ship B is located 5 km to the southeast of Ship A. The question seeks to determine how close the two ships will get to each other over time.
  • Mixed
  • Participants discuss setting up a coordinate system to track the positions of the ships over time. There are attempts to derive the distance between the ships as a function of time, with some participants questioning the initial positions and the setup of the equations.
Several participants have offered guidance on how to express the positions of the ships in coordinate form and have encouraged the use of derivatives to find the minimum distance. There is an ongoing exploration of the calculations involved, with some participants expressing confusion about the results.
Some participants express uncertainty about the correct interpretation of the initial positions and the implications of their coordinate choices. There are also discussions about the accuracy of calculations and the significance of rounding in the final answers.
thomasrules
Ship A, sailing due east at 8 km/h, sights ship B 5km to the southeast when ship B is sailing due north at 6km/h. How close to each other will the two ships get?
I drew the picture. Ship a distance is 8t and B is 6t
Use the a^2+b^2=c^2
Seems to me there are two coordinates of interest here. Hint.
sorry I'm lost
Use the a^2+b^2=c^2
"Ship a distance is 8t and B is 6t" distance from what? Set up a coordinate system, say with A initially at the origin. What are the coordinates of ship A at time t? What are the initial coordinates of ship B? What are the coordinates of ship A at time t? What is the (square of the) distance between those points as a function of t?
ok [tex]D^2=(-3.53+6t^2)+8t^2 dD/dt=(200t-42.36)/whatever\\0=200t-42.36\\t=0.212\\[/tex]
I plugged that in the distance formula and got a wrong answer
Follow HallsOfIvy's suggest and write down the position of the two ships in xy coordinates as a function of time first. It's difficult to tell where you went wrong from what you post.
yes I have a drawing. I used the sin law to find the distance of the 2 sides.
Coordinates (3.53,0) and (3.53,-3.53)
By the way how do you put spaces in latex coding I tried \\ it didnt work
Eeh??
Do you even know what coordinates are??
Considered as a function of time, what is ship A's position measured from an origin lying where A was, and sighted B somewhere at t=0?
And, with the same choice of origin, what is B's position as a function of time?
At what time? Where is the time dependence? (Not sure about your latex question, sorry).
yes those are the coordinates.from the origin (0,0) using pythagorean theorem,
i use 5sin45=a=3.53, b=3.53
1. What choice have you made of positive axes?
2. What was A's position at t=0?
3. What is A's position as a function of time?
4. What is B's position as a function of time?
A's position at t=0 is (0,0)
A's position as a function of time is (3.53-8t,0)
B's position as a function of time is (3.53,-3.53-6t)
Is (3.53-8*0,0)=(0,0)?? :confused:?
ah crap...
A is (8t,0)
**** or is it
A(8t,0)
B(3.53,-3.53+6t)
My guess is that's right if not I quit school
You can stay in school! Now what is D^2 as a function of t?
D^2=(-3.53+6t-0)^2+(3.53-8t)^2
I did derivative. Set it to 0. Got 0.7
Thats not the answer
I'm suppost to plug time into the D^2 and get the distance correct?
You seem to be trying to do the right thing. What is the derivative of D^2?
I got it to be:
After the expansion and derivative
dD/dt=200t-98.84/(the rest here doesn't matter cause I'm setting other side to zero)
All seems ok. What is the answer supposed to be?
The ships get 0.707km to each other
btw thanks for all your help so far
You're welcome. But that answer only differs from 0.7 because you are rounding off differently.
NO! but we only have found the time man not the distance
thomasrules said:
I got it to be:
You are saying your solution for the TIME is 0.7? That's not what this says.
OMG YOU ARE CORRECT!
Thanks man. I'm slow. What's your paypal how much do I owe you.
:-p
And now I have another similar one I'm struggling with it :S
Good luck!
Because you (cleverly) chose to make A's initial position the origin of your coordinate system, A's position at t= 0 is, indeed, (0,0). Since A is moving due east (and you chose to make the positive x-axis that direction) at 8 km/h, A's position at time t hours is (8t, 0). Yep, that's what you got!
Initially, B was "5 km to the south east" so B's initial position is [itex](5\frac{\sqrt{2}}{2}, 5\frac{\sqrt{2}}{2}[/itex] ([itex]sin(45^o)= \frac{\sqrt{2}}{2})[/itex]. Since B is moving straight North at 6 km/h, B's position at time t hours must be [itex](5\frac{\sqrt{2}}{2}, 5\frac{\sqrt{2}}{2}+ 6t)[/itex]). If [itex]5\frac{\sqrt{2}}{2}= 3.53[/itex](and it is) you are correct. Glad you don't have to quit school!
Now what is the distance between those points? (Hint: since distance is always positive, minimizing distance is the same as mininizing distance squared- so you can ignore the square root in the distance formula.)
Yea I got it thanks Halls of Ivy...
I get to stay in school :D
  • · Replies 17 ·
  • · Replies 21 ·
