Calculating Final Velocity of a Car Over a Ramp
The discussion revolves around calculating the final velocity of a car as it travels off a ramp. The problem involves concepts from kinematics and projectile motion, specifically addressing the effects of vertical and horizontal components of velocity.
  • The original poster attempts to calculate the final velocity using vertical motion equations, while others point out the need to consider both vertical and horizontal components of velocity in projectile motion. There is also a question about the validity of an alternative formula presented by another participant.
Participants are actively engaging with the problem, offering clarifications about vector addition and the nature of projectile motion. There is acknowledgment of different interpretations of the problem, and some guidance has been provided regarding the calculation of resultant velocity.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. The original poster's calculations and assumptions are being scrutinized for accuracy.
Drakon25th
OK, many people in my class got a different answer from each other, so could someone verify my work for me please? Here's the problem:
A car (m=1000kg) driving at 20 m/s goes over a ramp angled at 37 degrees with a height of 5 m. How fast is the car traveling when it hits the ground 15 m below the end of the ramp?
my work:
Vyo = 20m/s ( sin37º)
Vyo = 12.0 m/s
Vy = sqrt(vyo^2 + 2gy)
Vy = sqrt ((12m/2)^2 + 2 * 9.8m/s^2 * 15 m)
Vy = 21 m/s
So my answer was 21 m/s
edit: my webspace is down right now so can't post pic
is this correct or am i doing something wrong?
You forgot something
When the car hits the ground, it is not traveling perfectly vertical. Remember, for projectile motion, the horizonal velocity remains constant. Therefore you must add the final vertical velocity and the final horizontal velocity together (note they are vectors) to get a resultant velocity, which is on an angle that you must also calculate based on these velocities.
21 m/s is the velocity in the y direction. The resultant velocity vector (the velocity at which the car hits the ground) would be the sum of the vectors in the x and y directions.
The resultant vector would be: 12i -21j
The car would hit the ground at sqrt ( 21^2 + 12^2) m/s
The direction is given by arctan (21/12) S of E
oohh, i see, thanks
one question, could i use the formula:
sqrt ((.5Vo^2+gho-ghf)/.5) ?
what i mean:
sqrt ((.5 (20m/s)^2 + 9.8m/s^2 * 10m)/.5) = 24.4 m/s
Or would that not be right?
