Schwarzschild Metric Question again
The Schwarzschild Metric is valid for radial distances R greater than 2M, where R represents the radial coordinate and M denotes the mass of the gravitating body. The discussion clarifies that R and M can be expressed in compatible units, particularly when using Planck units, where both the gravitational constant G and the speed of light c are normalized to 1. It is emphasized that R=2M is a coordinate singularity rather than a physical one, and there are extensions of the Schwarzschild solution applicable for R less than 2M.
  • Understanding of the Schwarzschild Metric
  • Familiarity with Planck units
  • Knowledge of general relativity concepts
  • Basic grasp of coordinate systems in physics
  • Research extensions of the Schwarzschild solution for R<2M
  • Study the implications of coordinate singularities in general relativity
  • Explore the use of Planck units in theoretical physics
  • Learn about the physical interpretations of the Schwarzschild Metric
Students of physics, researchers in general relativity, and anyone interested in the mathematical foundations of black hole physics will benefit from this discussion.
franznietzsche
The Schwarzschild Metric is only valid for R>2M, What are the units used here? Obviously R and M should have incompatible units...so how can any comparison of this type be made?
We can only externally check its validity down to that limit, but that does not mean that it is only valid down to that limit.
In Plank units among other systems c = 1 and G = 1. So 2GM/c^2 = 2M. Specifically which system was used was up to whoever the author was.
There are extensions of the Schwarzschild solution for R<2M in other coordinates. R=2M is only a coordinate singularity, not a physical one.
  • · Replies 18 ·
