SI Unit Conversion Help: Mass Density of Aluminum and Alcohol
The discussion revolves around converting mass density measurements of aluminum and alcohol into SI units. The original poster presents two values: aluminum at 2.7*10^-3 kg/cm^3 and alcohol at 0.81 g/cm^3, seeking clarification on the conversion process.
  • Participants explore the nature of SI units versus other metric units, questioning whether the given measurements are in SI. There is discussion about converting grams to kilograms and cubic centimeters to cubic meters, with some participants suggesting specific conversion factors.
The conversation is active, with participants providing insights into the definitions of SI units and discussing the necessary conversions. There is acknowledgment of the need to convert units correctly, but no consensus has been reached on the exact steps to take.
Participants note the distinction between SI and cgs units, highlighting the importance of using the correct system for scientific measurements. The original poster's understanding of the problem is also questioned, indicating potential confusion about the requirements of the task.
Weave
Ok, this isn't hard, I'm just thrown off by the question. From the book: "The quantity called mass density is mass per unit volume of a substance. Express the following in SI units:"
a. Aluminum, 2.7*10^-3 kg/cm^3
b. Alcohol, .81g/cm^3
So do they want it just in g/kg?
A. multiply by cubic centimeters per kg
B. multiply by cubic centimeters per g
SI units don't simply mean "metric". There are very specific metric quantities that are considered SI units. For example, the SI unit for temperature is the Kelvin. If you were given a Celsius measurement, you'd have to convert that to Kelvin if you wanted to express the temperature in an SI unit.
You can see which units are SI units from this link:
http://en.wikipedia.org/wiki/SI
For example, in part a of your question, you're given kg and cm^3. One of those is SI and the other isn't.
SI units are also sometimes referred to as "MKS" units- the fundamental units of length mass and time are "Meter", "Kilogram", and "Second"- unit of force is the Newton, energy the Joule, etc. This is as opposed to the "cgs" system in which the fundamental units of length, mass, and time are "centimeter", "gram", and "second"- the unit of force is the dyne, energy the erg, etc.
In any case, your first measurement is 2.7*10^-3 kg/cm^3 which is in neither system. You need to convert grams to kilograms. The second measurement is .81g/cm^3 which is in cgs. You need to convert grams to kilograms to grams and centimeters to meters.
Use the "unit fractions" 1 kg/1000 g and 100 cm/ 1 m.
The first measurement was already in kg. :-)
The first one is already in Kg, so wouldn't I just convert the cm^3 to m^3?
The second one needs to be converted to kg, then cm^3 to m^3.
Yup! :-)
m^3 is an SI unit still, right?
Just imagine how odd it would be if you had two lengths expressed in SI units. You went to go multiply them together to find an area and you found that your area was not in SI units.
I think we'd all go back to using the English system...
  • · Replies 29 ·
12K
