Calculating Velocity and Time for Vertically Thrown Stones
The discussion revolves around a physics problem involving the motion of two stones thrown vertically downward from a cliff. The problem requires calculating the time it takes for both stones to hit the water and their respective velocities at that moment.
  • The original poster attempts to use the equations of motion to find the time and velocities of the stones. Some participants question the assumptions regarding the time each stone spends in the air, particularly the impact of the one-second delay in the release of the second stone.
Participants are actively engaging with the problem, with some providing guidance on correcting the interpretation of the time intervals for each stone. There is a recognition that the second stone must take less time to reach the water due to its later release, prompting further exploration of the implications of this realization.
There is a noted confusion regarding the application of the equations of motion, particularly in relation to the timing of the stones' release and their subsequent flight times. The problem also involves specific values for initial velocity and gravitational acceleration, which are central to the calculations being discussed.
Cummings
A simple problem but i can't seem to get the answer i am told. I am thinking that i have mixed up my equations of motion
The question i have to answer is this.
A boy throws 2 stones verticly downward from a 50meter high cliff inot a calm pool of water.The 2 stones are thrown 1 second apart and the first stones initial velocity is 2m/s downwards. The 2 stones are seen to have hit the water at the same time.
a, How long after the release of the first stone do the 2 stones hit the water?
b, what was the initial velocity of the second stone?
c, what are the velocity's of the 2 stones at the instant they hit the water?
for a i used s=ut+.5a(t squared)
s = distance (50m) u = initial velocity of stone 1 (2m/s) a = gravity (9.8m/s2) and t is the time in seconds.
from that i found t = 2.99 = the right answer
for b, i tried using s=ut+.5a(t squared) again but for the second stone. So i uped the time by 1 second as it was released one second after the first so t = 3.99 s = 50m a = 9.8m/s2 and u is unknown
i got u = - 7.02 m/s
but i am told the speed is -15.4 m/s
a little help would be appreciated.
Originally posted by Cummings
for b, i tried using s=ut+.5a(t squared) again but for the second stone. So i uped the time by 1 second[/color]
There[/color] is your problem: You went in the wrong direction. The second stone travels 1 second less than the first. You have it traveling 1 second more.
You have to subtract 1 second, not add it.
edit: typo
so if it was dropped 1 second later but hit at the same time, the time it spent in the air is actualy 1 second less?
i realize now that just because stone 1 took 2.99 seconds does not mean that stone 2 will take the same amount of time + 1 just because it was released a second after it. It seems clear that if it is dropped one second after it then it must take one second less time if it is to reach the ground at the same time.
All about visualising the problem. I knew it was the time that was stuffing me up but can't say i have had to visualise that before. Thanks.
Yes.
