Question on infinite curvature of the universe
The discussion centers on the implications of general relativity and quantum mechanics regarding the curvature of the universe. It highlights the role of the cosmological constant, which suggests that "empty space" possesses a positive energy density and negative pressure, leading to gravitational effects that cause the universe to expand. The conversation also touches on the paradox of how positive energy density can result in negative mass effects, indicating that empty space can gravitationally repel itself. This phenomenon remains an unsolved problem at the quantum level.
  • Understanding of general relativity principles
  • Familiarity with quantum mechanics concepts, particularly Heisenberg's uncertainty principle
  • Knowledge of the cosmological constant and its implications
  • Basic grasp of energy density and pressure in gravitational contexts
  • Research the implications of the cosmological constant on cosmic expansion
  • Study the relationship between energy density, pressure, and gravity in general relativity
  • Explore the concept of virtual particles in quantum field theory
  • Investigate current theories addressing the unsolved problems in quantum gravity
Astronomers, physicists, and students of theoretical physics interested in the intersection of general relativity and quantum mechanics, particularly those exploring cosmic expansion and the nature of empty space.
fauyd
Ok, so I don't know much about general relativity or quantum mechanics but, if gravity effects everything in the universe, and if Heisenberg's uncertainty principle makes it so that you can not have truly empty space (so every point of space has to have some sort of particle occupying it, bc if you did not then you would be able to measure in some way an exact point of space down to 0 variance in measurement) then wouldn't gravity just pull and curve every bit of space in on its self? Forgive my ignorance, and if the question makes no sense then just disregard it, lol.
if there isn't a particle there, how will you know which exact point in space you measured? Besides, there's no problem unless you also expect to measure the speed of that point in space, which you can't do anyway..:smile:
Cosmological measurements suggest that empty space does have gravitational effects. The main effect as it applies to GR is called the "cosmological constant" However, oddly enough, observations suggest that the net effect of the gravitational effect of the swarm of virtual particles in "empty" space is to make space expand, i.e. to make the expansion of the universe accelerate. At the quantum level, this is an unsolved problem as to why this happens.
It is possible to view the presence of the cosmological constant as implying that "empty space" has a positive energy density, a negative pressure, and what acts a lot like a negative mass.
How do you get a negative mass out of a positive energy density? Well, both energy and pressure contribute to gravity. See for instance http://www.math.ucr.edu/home/baez/einstein/
Because density + 3*pressure is negative, the effect is essentially one of "negative mass", in spite of the positive energy density. You can think of this as "empty" space gravitationally repelling itself - it "wants to" expand.
  • · Replies 47 ·
  • · Replies 30 ·
  • · Replies 32 ·
  • · Replies 22 ·
  • · Replies 95 ·
11K
