Solving System of Non-Linear Equations w/ MATLAB fsolve
  • Context: MATLAB
  • Thread starter Thread starter cianfro1
    Matlab
The discussion revolves around solving a system of non-linear equations using MATLAB's fsolve function. Participants explore issues related to the number of equations and variables, specifically addressing an error encountered when attempting to solve for more than five equations.
  • One participant reports successfully solving 5 equations but encounters an "index out of bounds" error when attempting to solve 20 equations.
  • Another participant suggests that fsolve does not have a limit on the number of equations, but emphasizes that the number of equations must match or exceed the number of unknowns.
  • Concerns are raised about the size and datatype of the variable 'r', questioning whether it is correctly defined to accommodate the required number of equations.
  • A participant asserts that the 'r' variable is indeed the issue, as it appears to be limited to 5 elements, leading to the error when accessing r(17).
  • One participant shares the actual code used for the problem, highlighting the equations defined in the function and the initial guess provided to fsolve.
  • Another participant points out that the initial guess array x0 has only 5 elements, which does not match the expected size for the function wsteady that requires 19 elements.
  • A later reply acknowledges the oversight regarding the initial guess and confirms that it was the source of the issue.
Participants generally agree that the initial guess must match the number of equations, but there is some debate about whether there is a limitation imposed by fsolve itself. The discussion remains unresolved regarding the specifics of any potential limitations of fsolve.
Participants note that the function to be solved must be continuous and that fsolve may converge to a nonzero point, suggesting the need for different starting values. There is also mention of the requirement for real variables, which must be split into real and imaginary parts if complex.
cianfro1
I'm trying to solve a system of non-linear equations. I was successful in solving 5 equations/5unkowns with the function fsolve. However, when I have more than 5, I get the error message:
? Attempted to access r(17); index out of bounds because numel(r)=5.
How do I increase that size so that I can solve for 20 equations, instead of a mazimum of 5?
It seems as if there isn't a limit.
For fsolve, the nonlinear system of equations cannot be underdetermined; that is, the number of equations (the number of elements of F returned by fun) must be at least as many as the length of x ...
Furthermore, it's not listed as a limitation:
Limitations
The function to be solved must be continuous. When successful, fsolve only gives one root. fsolve may converge to a nonzero point, in which case, try other starting values.
fsolve only handles real variables. When x has complex variables, the variables must be split into real and imaginary parts.
I'm not familiar with MATLAB... are you sure your "r" variable is the correct size/datatype, to hold a value at index 17? And are you sure that you've correctly specified all 20 some functions?
the 'r' variable is not the problem. Even if I do a test system of equations with 6 equations, it has the same problem. There must be some default that will only solve for 5 equations. If that is the case, I can't find out how to change it.
As I understand it, the 'r' variable is precisely the problem. There's a read error when trying to access r(17), which means r(17) does not exist. The length of r is 5.
Whether or not that is a restriction imposed by fsolve, I'm not sure. But I'd assume it's not a limitation, since it's not listed as one under the documentation. Furthermore, searching for this problem on Google yields absolutely nothing of any relevance.
If it is a limitation, they should update their documentation. Otherwise, try posting your code here. Maybe someone can spot some error in your code.
Actual Code of Problem
function z = wsteady(r,Et,Ti,Ta,Tdp,v,sigma,absorb,Fe,emiss,Wf,Rfb,Rfins,vamb,Dh,L,P,A,Ub,Uins,hi,density,mdot)
z(1) = r(1) - (0.75*r(17) + 0.25*Ta);
z(2) = r(2) - ((Ta-273)*(0.8004 + 0.00396*(Tdp-273))^0.25 + 273);
z(3) = r(3) - (1006+0.05*(r(1)-273));
z(4) = r(4) - ((0.09485*(r(1) - 273) + 13.278)/1000000);
z(5) = r(5) - ((0.02795*(r(1) - 273) + 24.558)/1000);
z(6) = r(6) - (v*Dh/r(4));
z(7) = r(7) - (r(4)*r(3)*density/r(5));
z(8) = r(8) - (sigma*Fe*(r(16)^4-r(18)^4)/(r(16)-r(18)));
z(9) = r(9) -(0.5*sigma*emiss*(r(15) ^4-Ta^4)/(r(15) -Ta));
z(10) = r(10) - (0.3535*sigma*emiss*(r(15) ^4-r(2)^4)/(r(15) -r(2)));
z(11) = r(11) - (0.1465*sigma*emiss*(r(15) ^4-Ta^4)/(r(15) -Ta));
z(12) = r(12) - (2.537*Wf*Rfb*(P*vamb/A)^0.5 + 1.31*(abs(r(15) - Ta))^(1/3));
z(13) = r(13) - (Rfb*r(5)/Dh*(5.4 + 0.00190*(r(6)*r(7)*Dh/L)^1.71/(1 + 0.00563*(r(6)*r(7)*Dh/L)^1.17)));
z(14) = r(14) - (Rfins*r(5)/Dh*(5.4 + 0.00190*(r(6)*r(7)*Dh/L)^1.71/(1 + 0.00563*(r(6)*r(7)*Dh/L)^1.17)));
z(15) = absorb*Et - (r(12)*(r(15) -Ta) + r(9)*(r(15) -Ta) + r(10)*(r(15) -r(2)) + r(11)*(r(15) -Ta) + Ub*(r(15) -r(16))); % + bden*br(3)*bvol*(r(15)-Tref)
z(16) = Ub*(r(15) -r(16)) - (r(13)*(r(16)-r(1)) + r(8)*(r(16)-r(18)));
z(17) = mdot*r(3)*(r(17)-Ta) - (r(13)*(r(16)-r(1)) + r(14)*(r(18)-r(1)));
z(18) = r(8)*(r(16)-r(18)) - (Uins*(r(18)-r(19)) + r(14)*(r(18)-r(1)));
z(19) = Uins*(r(18)-r(19)) - (hi*r(19)-Ti);
I recall the function using the following code:
sigma = 5.67e-8;
absorb = 0.8;
emiss = 0.9;
Fe = 0.82;
Etwinter=900;
Ti = 296;
Tawinter=268;
Tdpwinter=263;
Wf = 1;
vamb=2;
absorb = 0.8;
sig = 0.0000000567;
emiss = 0.9;
Fe = 0.82;
L=1.8288;
W=0.8128;
gap = 0.0254;
A = W*L;
Dh = 2*gap;
P = 2*W + 2*L
Rfb = 1.67;
Rfins = 2.17;
Uins = 0.283;
Ub = 13.4;
hi = 8.29;
vwinter = 0.8;
densitywinter = 288.15/Tawinter*1.2255;
mdotwinter = densitywinter*gap*vwinter;
options=optimset('FunValCheck','on');
x0=[290,287,288,297,296];
winter = fsolve('wsteady',x0,options,Etwinter,Ti,Tawinter,Tdpwinter,vwinter,sigma,absorb,Fe,emiss,Wf,Rfb,Rins,vamb,Dh,L,P,A,Ub,Uins,hi,densitywinter,mdotwinter);
<snip>
The array x0 has 5 elements and that is passed to the function wsteady as the variable r. So, as Sane said above, the length of array x0 should at least be as long as the variable r used in the function (which is 19 elements I believe).
wow... i overlooked the initial guess. The code was edited from 5 equations to 19 and i forgot to change that part! You guys were both right. Thank you very much!
11K
