Calculating Magnetic Fields Force & Momentum
The discussion focuses on calculating the momentum and angular momentum of a charged particle in a magnetic field. The particle has a charge of 4.5E-19 C and travels in a circular orbit with a radius of 0.465 m under a magnetic field of 1.7 T. The linear momentum (mv) was calculated to be 3.6E-19 kg*m/s. The angular momentum was derived using the formula L = mv*r, resulting in a value of 1.674E-19 kg*m^2/s, with the direction being perpendicular to both the velocity and the radius of the orbit.
  • Understanding of magnetic fields and forces
  • Familiarity with the concepts of linear momentum and angular momentum
  • Knowledge of the equations R=(mv)/(qB) and L=mvr
  • Basic principles of circular motion
  • Explore the relationship between charge, magnetic fields, and circular motion
  • Learn about the implications of angular momentum in different physical systems
  • Study the effects of varying magnetic field strengths on charged particles
  • Investigate the role of angular momentum in quantum mechanics
Students and professionals in physics, particularly those studying electromagnetism, mechanics, and anyone involved in particle dynamics in magnetic fields.
eku_girl83
Here's my problem:
A particle with charge 4.5E-19 C travels in a circular orbit with radius .465 m due to the force exerted on it by a magnetic field with magnitude 1.7 T and perpendicular to the orbit.
a) What is the magnitude of the momentum p of the particle?
I used the equation R=(mv)/(qB) and calculated mv (linear momentum) to be 3.6E-19 kg*m/s.
b) What is the magnitude of the angular momentum L of the particle?
Herein lies the rub! Angular momentum = v/R = qB/m
I don't know velocity or mass independently, only their product (mv). So how do I calculate angular momentum?
Thanks for any help!
angular speed: ω = v/r
angular momentum: L = r x p
Since your particle is moving in a circle, it's linear momentum vector p is always perpendicular to the position vector (radius) r so the angular momentum is simply the product:
L = rp = rmv
Your approach to finding the linear momentum of the particle is correct. To find the angular momentum, you can use the formula L = mvr, where m is the mass of the particle, v is its velocity, and r is the radius of the circular orbit. Since you already know the value of mv, you can rearrange the equation to solve for angular momentum: L = mv*r.
In this case, the value of mv you calculated in part a) can be used, and the radius of the orbit is given as 0.465 m. Therefore, the angular momentum of the particle is L = (3.6E-19 kg*m/s)*(0.465 m) = 1.674E-19 kg*m^2/s.
Remember, angular momentum is a vector quantity, so make sure to include the correct direction in your answer. In this case, the direction of the angular momentum would be perpendicular to both the velocity and the radius of the orbit.
I hope this helps! Good luck with your calculations.
  • · Replies 26 ·
  • · Replies 17 ·
