What Is the Rate of Change of the Cone's Height When the Radius Is 3 Units?
  • Thread starter Thread starter NewsboysGurl91
    Related rates
The discussion revolves around calculating the rate of change of the height of a cone when its radius is 3 units and its volume is increasing at 28pi cubic units per second. The formula for the volume of a cone, V = 1/3*pi*r^2*h, is used to derive the height, which is found to be 4 units. The participants debate the application of the product rule in differentiation, particularly how to correctly apply the constant factor of 1/3*pi. Ultimately, the correct rate of change of the height, dh/dt, is determined to be 4pi units per second. The conversation highlights the importance of careful differentiation and accurate calculations in related rates problems.
NewsboysGurl91
The volume V of a cone (V = 1/3*pi*r^2*h) is increasing at the rate of 28pi cubic units per second. At the instant when the radius r of the cone is 3 units, its volume is 12pi cubic units and the radius is increasing at 1/2 unit per second. At the instant when the radius of the cone is 3 units, what is the rate of change of the area of its height h?
Know: dV/dt = 28pi cubic units per second, dr/dt = 1/2 unit per second, and dA/dt = 3pi units square per second. Need: dh/dt
12pi = 1/3pi*3^2*h
h=4
V = 1/3*pi*r^2*h
dV/dt = 1/3*pi*2r*dr/dt*h + r^2*dh/dt (use the product rule. do you multiply 1/3 pi times everything like this 1/3*pi(2r*dr/dt*h + r^2*dh/dt) or how I did it?)
28pi = 1/3pi*2(3)*1/2*4 + 6*dh/dt
24pi = 6*dh/dt
dh/dt = 4pi units per second
Is this correct?
12pi = 1/3pi*3^2*h
h=4
V = 1/3*pi*r^2*h
What you have is wrong. You can either think of this as V= (1/3)(pi r^2h) so that dV/dt= (1/3)d(pi r^2h)/dt or do it as V= ((1/3)pir^2)(h) so that dV/dt= {d((1/3)pir^2)/dt}h+ ((1/3)pi r^2)(dh/dt). Either way, the (1/3)pi multiplies the entire derivative:
dV/dt= (2/3)pi rh dr/dt+ (1/3)pi r^2 dh/dt.
28pi= (1/3)pi(2)(3)(1/2)(4)+ (2/3)pi (9) dh/dt
(Where did you get that "6"? if r= 3, r^2= 9, not 18!
24pi = 6*dh/dt
Is this correct?
No, it isn't!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
  • · Replies 30 ·
