Does "What You Don't See" Apply to Special Relativity?
The discussion revolves around the application of the phrase "What you don't see with your eyes, don't invent with your mouth" in the context of special relativity. Participants explore the implications of abstract concepts in relativity, particularly regarding observations and the visibility of phenomena like Lorentz contraction.
  • Some participants suggest that abstract concepts are essential in relativity, but caution that incorrectly applying Newtonian abstractions can lead to misunderstandings.
  • There is a discussion about whether Lorentz contraction can be visually observed, with references to differing opinions among authors, including Terrel.
  • One participant proposes that discussing observations rather than abstractions may help avoid confusion, provided all parties are committed to this approach.
  • Another participant notes that while a perfect sphere's contraction may not be visually observable, other shapes, like a long rectangle or rod, could potentially be photographed to demonstrate length contraction.
  • Thought experiments are mentioned as a method to make abstract concepts more tangible.
Participants express differing views on the visibility of Lorentz contraction and the role of abstract concepts in understanding relativity. No consensus is reached on these points.
The discussion highlights the complexity of translating abstract concepts into observable phenomena and the potential for misinterpretation when applying classical ideas to relativistic contexts.
bernhard.rothenstein
Does " What you don't see with your eyes, don't invent with your mouth" does work in special relativity?:smile:
Your post is a bit vague - you must have something specific in mind!
Abstract concepts are very useful in relativity, as elswhere. This is what I assume is meant by "don't see with your eyes" - abstractions.
But sometimes people incorrectly carry over abstract concepts that used to work in Newtonian theory to relativity. This can be a problem.
Discussing everything in terms of observations (i.e. no abstractions, take everything down to the lowest level of what is actually measured and directly observed) is more work, but is one way (and one of the better ways) of avoiding or sidestepping the trap of incorrrect abstract concepts, if all parties are sufficiently dedicated, patient, and have enough time.
believe what you see?
When I posted the thread I did not have a clear answer to the question proposing it only for relaxation. Pervect's answer is interesting. In between I remembered an old question in special relativity: Can we see the Lorentz contraction? As far as I know there are authors who consider that we are not able to see it (Terrel?) and others who consider that under certain circumstances we can. Are thought experiments a way to make abstract concepts more palpable?
Thanks. Do you mean by abstract "instantaneous velocity", "instantaneous frequency"...? Using photographic detection or radar detection we can compare (see) the snapshots or the radar screens of two observers in relative motion. Such approaches ensure the fact that we believe what we see?
The not being able to see (or photograph) the Lorentz length contraction of a moving object only applies to the case of a perfect sphere. The length contraction of a long rectangle or rod for example can be photographed. The demonstration that the the length contraction of a sphere cannot be visually photographed is seized upon by too many to imply (incorrectly) that length contraction cannot be seen in ANY object and that length contraction is an illusion.
Oops, just noticed this is a very old thread. Sorry! Stumbled across it when searching for something else.
  • · Replies 37 ·
  • · Replies 29 ·
