Help with two problems with empirical formula
  • Thread starter Thread starter Pepsi24chevy
    Formula
The discussion revolves around two problems related to determining the empirical formula of compounds containing carbon, hydrogen, nitrogen, and oxygen based on combustion data. Participants are seeking help in setting up and solving these problems, which involve calculations based on the mass of products formed during combustion.
  • Homework-related
  • One participant expresses familiarity with empirical formulas but struggles with the specific problems presented, asking for assistance in setting them up.
  • Another participant requests to see the work done so far to provide help.
  • A hint is given to use the mole concept for calculations.
  • One participant attempts calculations for the first problem but realizes they may not be correct and hesitates to proceed with the second problem.
  • A different participant critiques the calculations, pointing out errors in the approach and the need to convert mass from milligrams to grams for accurate mole calculations.
  • Concerns are raised about the balancing of the chemical equation and the treatment of nitrogen in the combustion process.
  • Another participant suggests that nitrogen may be burned off during combustion, indicating confusion about its role in the reaction.
  • A participant questions the conservation of mass, noting that the mass of products seems to exceed the initial mass of the compound, prompting clarification about the nature of combustion reactions.
  • Further discussion includes a critique of the initial calculations and prompts for determining the mass and moles of nitrogen, as well as the mole ratios of the elements involved.
Participants express confusion and disagreement regarding the correct approach to the problems, particularly in the treatment of nitrogen and the application of the conservation of mass. No consensus is reached on the correct methodology or interpretation of the combustion process.
Participants highlight limitations in understanding the combustion process, particularly regarding the role of nitrogen and the implications of mass conservation in chemical reactions. There are unresolved mathematical steps and assumptions about the reactions taking place.
Pepsi24chevy
Hey, i know how to do empirical formula regularly but nto with all this other stuff in these problems. COuld someone help me set these 2 problems up.
1.A compound contrains only C,H, and N. Combustion of 35.0mg of the compound produces 33.5mg CO2 and 41.1mg H2O. What is the empirical formula of the compound?
2. A compound contrains only carbon, hydrogen, nitrogen, and oxygen. COmbustion of 0.157g of the compoudn produced 0.213 g CO2 and 0.0310g H2O. In another experiment, it is foudn that 0.013g of the compound produces 0.0230g NH3. What is the empirical formula of the compound? Combustion involves reacting with excess O2. Assume that all the carbon ends up in the CO2 and all the hydrogen ends up in H2O. Also assume that all the nitrogen ends up in the NH3 in the second experiment.
Chemistry news on Phys.org
Show us the work you've done, and I'll show you what I can do.
HINT: Use Mole Concept
Well i started out by doing 33.5* (1/44.0098)*12.001 = 9.14
33.5*(1/114.0098) * 31.9988 = 24.36
41.1 * (1/18.01534) * 2.01594= 4.60
41.1 * (1/18.01534) *15.9988= 36.50
Then i thought about dividing the numbers by the smallest, but then i figured i wasn't doing it right. FOr the second one i didn't start it becasue i figured i wasnt' doing the first one right.
Okay, that appears to be quite wrong. You do not multiply the moles of substance by the molar mass of carbon/oxygen. And you have 33.5 MILLIgrams, that's 0.00335 g. And in question 1 you write the compound contains C, H and N.
So. Now you find out how many moles 0.00335 g of CO2 is. Do the same for H2O. Now you can multiply it by a comon factor to get a nice number, if necessary. Goddammit these problems are bugging me so I'll just do the first one...
You find that the ratio is 3:1 H2O:CO2
x(C&H&N) + O2 --> 3H2O + CO2
This doesn't even make sense. Where the hell does the nitrogen go? It's not balanced and so it discourages my doing it.
I am still confused. The nitrogen is burned off maybe?
i don't know if i am right but
okay you start out with 35.0mg, but then on the other end of the equation, you have more that 35.0mg, doesn't that violate the mass conservation law?...oh well, just my imput.
It's being combusted, ie. it's reacting with oxygen. That's where the missing mass comes from. I don't know how good you are with chemistry, and I appologize if I make you feel dumb, but conservation of mass really means the conservation of combined mass on reaction side = combined mass on products side.
Good, mass of carbon.
Waste of time.
Good, mass of hydrogen
WOT.
Now, what's the mass of nitrogen in the sample? How many moles of carbon, hydrogen, and nitrgen? What are the mole ratios?
9K
9K
12K
