Solving Gravitational Forces on a Circular Disk with String Attached
This discussion focuses on solving the gravitational forces acting on a homogeneous circular disk with a string attached, as described in a physics homework problem. The mass of the disk is denoted as M, with a radius R, and it rolls on a horizontal surface while a bob of mass M is suspended from a frictionless pulley at a height of 2R. The equations of motion for both the bob and the disk are derived, leading to the expression for the string force S as S = (1/3)(Mg - 2f). The discussion emphasizes the importance of correctly identifying the direction of friction and its role in preventing slipping, as well as the need for additional equations to fully describe the system's dynamics.
  • Understanding of Newton's laws of motion
  • Familiarity with rotational dynamics and torque
  • Knowledge of frictional forces and their effects on motion
  • Ability to analyze systems involving pulleys and connected masses
  • Study the principles of rotational dynamics, focusing on torque and moment of inertia
  • Learn about the role of friction in rolling motion and its impact on stability
  • Explore the concept of tension in strings and its applications in pulley systems
  • Investigate the conditions for rolling without slipping and the calculations involved
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their understanding of dynamics involving rotational motion and friction.
P3X-018
(See the attachment)
A thin string has been wound around a homogeneuos circular disk A in such a way that the disk can roll on a horizontal surface. The mass of the disk is M, and has radius R. The string goes around a small frictionless pulley C at a height 2R above te horizental table B. To the free end of the string a bob of mass M is attached.
It is further assumed that the coefficient of friction [itex]\mu[/itex] is so large that the disk rolls without slipping on the horizontal table.
1. Determine the magnitude of the force S, with which the string acts on the disk as long as the system moves under the influence of gravity.
2. Determine the smallest value of [itex]\mu[/itex] that permits the disk to roll without slipping.
The way I tried solving the first problem, is to first write down the equation of motion of the bob, as
[tex]M\ddot{y} = Mg-S[/tex]
And the equation of motion for rotation
[tex]I_{CM}\ddot{\theta} = RS + Rf[/tex]
where [itex]f[/itex] is the force of friction on the disk providing a torque in the same direction as the strong force [itex]S[/itex].
Since the string is considered taut throughout the motion we can use the relation between the acceleration and angular acceleration, [itex]\ddot{y} = R\ddot{\theta}[/itex]. When I solve for the string force, by using that [itex]I_{CM} = MR^2/2[/itex] I get
[tex]S = \frac{1}{3}(Mg - 2f)[/tex]
But this result looks wrong, because the string force would be negative if the friction force is [itex]f > Mg/2[/itex].
Shouldn't a "negative" string force appear when if the frictional force was smaller than some given value, which would imply that disk would slip?
So the equations of motion must be wrong. Any hint to what I do wrong?
Btw, how would the equations of motion be if I had to calculate the equation of motion for the rotation around the point of contact with the surface B? The frictional force wouldn't even be in the equations would it? Because there is a hint saying that you can try calculating the torque around the point/axis of contact.
Good.
Which direction does friction point? Remember that friction acts to prevent slipping.
Once you correct that error you'll have the equation for rotation about the center of mass. But what about the translational motion of the disk? That will give you the third equation that you need.
Using that approach (which is perfectly OK) effectively combines two of the three equations needed in your intial approach. Of course, that won't help with question 2, since you need to know the friction to answer that one. :wink:
  • · Replies 24 ·
