Thread Closed
electricity and magnetism
Share Thread Thread Tools
Jan24-07, 08:58 PM   #1
Two identical conducting spheres each having a radius of .5 cm are connected by a light 2.3 m long conducting wire. A charge of 53 uC is placed on one of the conductors. Assume that the surface distribution of charge on each sphere is uniform. Determine the tension in the wire.
2. Relevant equations
F(electricity)=(k*q1*q2)/r^2
E=Q/epsilon
E=F/Q
F(electric)-T=0
3. Attempt
Since it's connected by a wire(I'm not sure how the wire plays a roll in this other than tension), I said that the charge instantaneously distributes to the other spheres so that both of them will have equal amount of charge(I'm not sure if the assumption is correct) I then solved for F(electric) which is equal to T, but I'm missing something because answer is not right. Can someone plz help?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan24-07, 09:11 PM   #2
Recognitions:
How much charge did you put on each sphere?
What distance did you use for the separation?
Jan24-07, 09:24 PM   #3
well the the thing is I wasn't sure what the length of wire is for, now I think I know it's for how far apart they are. For the F(electric) and the question just says 53uC of charge is put into one sphere so I assumed there were no charges in them beforehand. So then, I assumed that each sphere will have 26.5 uC of charge so F(electric) would just be (k*q^2)/(length of wire)^2? But it seems like since they're spheres and not point charge(unless that's what we're suppose to assume) I need to include another equation?
Jan24-07, 11:14 PM   #4
Recognitions:
Homework Helper Homework Help
the uniform charge distribution hints that the effective points are the centers of the spheres
Jan24-07, 11:30 PM   #5
so that means we can take into account that they're just like pt charges then?
So the distance between them is the length of wire and they both have same charge correct? So I just use F(electric)=k(q^2)/distance of wire^2 then i putinto force equation?
Jan25-07, 09:13 AM   #6
Recognitions:
Quote by feelau View Post
Exactly
Not quite. You need the distance between the centers of the spheres.
Jan25-07, 12:18 PM   #7
ah, my TA talked about this and he said that since r is so small, it's negligible
Jan25-07, 12:40 PM   #8
Recognitions:
Why wouldn't you include it, however? It's no harder to enter the correct value (2.31) than the wrong one (2.3)...
Thread Closed
Thread Tools
Similar Threads for: electricity and magnetism
Thread Forum Replies
Electricity and Magnetism Advanced Physics Learning Materials 4
Electricity and Magnetism Introductory Physics Homework 1
Which came first - Electricity or Magnetism? Classical Physics 6
Electricity and Magnetism Introductory Physics Homework 5
