How Is the Magnitude of an Electric Field Calculated from Electron Displacement?
The problem involves calculating the magnitude of an electric field based on the displacement of an electron released in a uniform electric field. The context is rooted in concepts of electric forces and kinematics.
  • Participants discuss the need to calculate average acceleration and relate it to the force exerted by the electric field. There are questions about the correct equations to use, including references to Newton's second law and the Lorentz force. Some participants express uncertainty about the application of these concepts.
Participants are exploring various approaches to the problem, with some guidance provided regarding the need to consider acceleration and the correct equations. There is a mix of understanding and confusion, particularly around the application of the Lorentz force and kinematic equations.
Some participants mention a lack of familiarity with certain concepts, such as the Lorentz force, and express a need for clarification on the relevant equations. There is also an acknowledgment of the complexity of the problem due to the interplay of forces involved.
stylez03
An electron is released from rest in a uniform electric field. The electron accelerates vertically upward, traveling 4.50 m in the first 3.00\;\mu{\rm s} after it is released.
What is the magnitude of the electric field?
F = 1/4*pi*e_o * |q| / r^2 for single point charge
e_o = 8.85 * 10^-12
Mass of electron = 9.109 * 10 ^-31
1/(4*pi*8.85 * 10^-12) * ( |9.109 * 10 ^-31| / (4.50)^2 )
The online system said the solution was incorrect.
Note the problem hints at an acceleration; you'll need to calculate the aveage acceleration of the particle, and then use Newton's second law to relate it to the force applied by the field. You need to account for another force here too; do you know what it is? Then you need an equation that relates the net force to both charge and electric field. As an aside, your first equation gives the force between two point charges, which is not the situation here, and in any case it is incorrect as written.
Can anyone answer my tension/friction question, please.
Can you list the equations that's necessary? I'm not sure which equations you're talking about. Thank you
The electric part of the Lorentz force, and Newton's second law.
I'm no familiar with Lorentz force, the section we're in is introduction to Electricity and the only equation I've seen so far is Coulomb's Law.
F = k*|q1|*|q2| / r^2
If you could start me off with an equation that would be most helpful. I can't see where I have to go with the givens I have so far.
The electric Lorentz force is
F=q*E
in SI units.
So we have the particle traveling 0.45m in the first 3us and you said I had to find the average acceleration?
Velocity = 4.50m / 0.000003 seconds = 1.5*10^6 m/s
Now we have to take the avg. acceleration which should be the change in velocity divided by the change in time? Would that just be that solution divided by 3us again to obtain that value?
You need to take a look in your book. The formula relating distance to acceleration and time is
x=0.5*a*t^2
Did you find it? Make sense?
Suggest you ask your teacher for some help.
Makes sense, I just got it! Thanks again. It's been a very long time since I've done kinematics.
