What is the Squeeze Theorem and How to Use It in Sequence Calculus Problems?
  • Thread starter Thread starter rcmango
    Theorem
The Squeeze Theorem is a fundamental concept in sequence calculus used to evaluate limits, particularly when dealing with bounded functions like cosine. In the given example, the limit of cos(n)/sqrt(n) as n approaches infinity is evaluated using the inequalities -1/sqrt(n) <= cos(n)/sqrt(n) <= 1/sqrt(n). The theorem requires that the function being evaluated is placed between two simpler functions whose limits are easily determined. It is not necessary for the bounding functions to be negative; they simply need to converge to the same limit.
  • Understanding of limits in calculus
  • Familiarity with the Squeeze Theorem
  • Knowledge of trigonometric functions, specifically cosine
  • Basic algebraic manipulation skills
  • Study the application of the Squeeze Theorem in different calculus problems
  • Learn about the properties of bounded functions in calculus
  • Explore the relationship between sine and cosine functions in limit evaluations
  • Investigate other limit evaluation techniques such as L'Hôpital's Rule
Students studying calculus, particularly those focusing on limits and sequence analysis, as well as educators teaching the Squeeze Theorem and its applications in mathematical problems.
rcmango
using the squeeze theorem:
lim cosn / sqrt(n)
n -> infinity
cos/n/sqrt(n) and 1/sqrt(n)
I just have a question about the squeeze theorem.
From my understanding, when using the squeeze theorem for these time of sequence calculus problems, I am always going to have the original equation in the middle?
also, why does one side of the squeeze theorem need to be negative?
this sequence approaches 0.
heres the work:
-1/sqrt(n) <= cosn/sqrt(n) <= 1/sqrt(n)
and, if this happened to be sin instead of cosine, would i just put 0 on both sides of the <= instead of the equations.
thanks a lot.
it doesn't have to be always negative on the LHS. The idea of the squeeze theorem is to find TWO "simple" functions that you can "squeeze" you function into. Simple in the sense that their limits are easy to evaluate. Of course, you need them to approach the same limit. In this case, you have a negative function -1/sqrt(n) because you know that Cos(n) is bounded by -1 (from below) and +1 (from above).
by the way, in your example n->0, function doesn't approach a finite value.
You need your function in the middle only when you want to find the limit of that function as it approaches some number. In other cases, such as when you just want to find some lower/upper bound (note: may not be the greatest lower or least upper bound) of your function then, you just need to restrict it on one side.
anyway squeezing theorem or sandwich theorem gets its name because you do put your function in the middle when finding limits of complicated function.
thanks for all your help.
