Time it take for small objects to come together under gravity
  • Context: Undergrad
  • Thread starter Thread starter hover
    Gravity Time
The discussion centers on calculating the time it takes for small objects to come together under gravity, specifically using the gravitational formula G*M/r², where G is 6.67*10^-8 cm³/g-sec². Participants highlight the complexity of non-constant acceleration in this scenario, suggesting the need for integration of the acceleration function. A recommendation is made to initially simplify the problem by using constant acceleration to find the time, as this approach is more straightforward for those with limited calculus knowledge.
  • Understanding of gravitational force and the formula G*M/r²
  • Basic knowledge of calculus, particularly integration
  • Familiarity with concepts of constant versus variable acceleration
  • Experience with physics experiments involving gravitational attraction
  • Study integration techniques for variable acceleration in physics
  • Learn about gravitational force calculations using G*M/r²
  • Explore constant acceleration equations and their applications
  • Investigate resources on gravitational experiments and their outcomes
Physics students, educators, and hobbyists interested in gravitational experiments and the mathematical principles behind gravitational attraction.
hover
Hey everyone!
I've done http://www.fourmilab.ch/gravitation/foobar/" and i find it interesting how objects of any mass just randomly attract each other. Anyway, i always wanted to find out how long it should take for a mass in this experiment to gravitate towards the other. The problem is it isn't like doing it on Earth where at the surface everything accelerates at 9.8m/s. The only relevant equation for acceleration in this case would be
G*M/r^2
G=6.67*10^-8cm³/g-sec²
m=mass in grams
r=distance in cm
I just learned a LITTLE calculus but so far i can only calculate how long it will take for an dropped object to hit the ground. I was hoping i could use this but since the acceleration is always changing i don't know how to do this out. Can someone help??
Thanks:smile:
Hi hover,
I've done this experiment and i find it interesting how objects of any mass just randomly attract each other.
Really? Where you expecting them to repel each other :biggrin:
So you want to complicate things more with non constant acceleration I see. I don't know the extent of your calculus knowledge, but this involves integrating the acceleration function.
http://www.sunybroome.edu/~biegen_j/phys1/modules/varacc/Mod4_3.htm
http://hyperphysics.phy-astr.gsu.edu/hbase/avari.html
I recommend for situations like this, you should use constant acceleration and find the time like you would normally.
  • · Replies 51 ·
  • · Replies 17 ·
