Hydrostatics Relation for Seawater Pressure with Temperature Variation
  • Thread starter Thread starter srh
    Hydrostatics
The discussion focuses on deriving the pressure as a function of depth in seawater using the hydrostatic relation and an empirical formula relating pressure and density. The formula provided is p/pa = (k+1)(d/da)^7-k, where pa is the surface pressure, da is the surface density, and k is a dimensionless constant. The hydrostatic relation dp/dz = -dg is utilized, with temperature expressed as T = T0 - kz and density as d = P/RT. The participant struggled with the complexity of the derivatives and sought clarification on the correct approach to incorporate depth into the equations.
  • Understanding of hydrostatic pressure principles
  • Familiarity with empirical formulas in fluid mechanics
  • Knowledge of thermodynamic equations, specifically the ideal gas law
  • Basic calculus, particularly differentiation techniques
  • Study the derivation of hydrostatic pressure equations in fluid mechanics
  • Learn about the implications of temperature variation on seawater density
  • Explore the application of the ideal gas law in varying conditions
  • Review techniques for simplifying complex derivatives in calculus
Students in physics or engineering disciplines, particularly those focusing on fluid mechanics, thermodynamics, or environmental science, will benefit from this discussion.
srh
An empirical formula relating pressure and density for seawater w/ temperature constant is:
pa - pressure condition on the surface
da - density condition on the surface
k - dimensionless constant
Using this formula in the hydrostatics relation, determine the pressure as a function of depth.
Hydrostatic relation: dp/dz = -dg where d is density
T=T0-kz
d=P/RT
I tried to replace d w/ P/RT and then T w/ T0-kz to get the equation in terms of z. When I tried to take the derivative it was getting very complicated and I couldn't get it to work. I think I'm just approaching the problem incorrectly. I was wondering exactly how to start this problem. I know in order to take the derivative w/ respect to z there needs to be a z in the equation.
Why do you need to differentiate with the hydrostatic relation?
16K
