What Are Other Solutions to the Equation 1/x + 1/y = 1/z for Integer Values?
  • Context: Undergrad
  • Thread starter Thread starter murshid_islam
The discussion revolves around finding integer solutions to the equation \(\frac{1}{x} + \frac{1}{y} = \frac{1}{z}\). Participants explore various methods and approaches to derive solutions, including specific cases and transformations of the equation.
  • One participant suggests that \(x = y = 2z\) is a set of solutions and inquires about other possible solutions.
  • Another participant questions the utility of finding the multiplicative inverse of both sides of the equation, leading to a derived expression for \(z\).
  • A participant transforms the equation and discusses conditions under which \(z\) is an integer, emphasizing the need for common factors between \(x\) and \(y\).
  • Some participants express confusion regarding the reasoning about common factors and the implications for integer solutions.
  • Discussion of Egyptian fractions is introduced, with a participant providing historical context and examples of how these fractions relate to the equation.
  • A method involving substitutions \(x = z + a\) and \(y = z + b\) is proposed, leading to a factorization approach to find integer solutions.
  • Another participant validates a method and shares a similar approach, highlighting the necessity of common factors in \(x\) and \(y\) for integer solutions.
  • Further exploration of the implications of perfect squares and common factors in relation to the equation is presented.
Participants express a range of views, with some agreeing on the necessity of common factors for integer solutions, while others remain uncertain or confused about specific reasoning and methods. The discussion does not reach a consensus on a singular approach or solution.
Some participants note limitations in understanding certain methods and the implications of common factors, indicating that further clarification may be needed. The discussion includes various assumptions and conditions that are not universally accepted.
murshid_islam
what are the solutions of the equation [tex]\frac{1}{x} + \frac{1}{y} = \frac{1}{z}[/tex] where [tex]x, y, z \in \mathbb{Z}[/tex]
i can see that x = y = 2z is a set of solutions. is there any other? and how do i find those?
thanks in advance.
Mathematics news on Phys.org
What is the multiplicative inverse of both sides of the equation?
i am sorry. i didn't understand how that would help. i got [tex]z = \frac{xy}{x+y}[/tex]
Transform the expression as such
[tex]\frac{x+y}{xy} = \frac{1}{z}[/tex]
[tex]\frac{xy}{x+y} = z[/tex]x and y can obviously not be both odd. Also, if there's no common factor between x and y, then z is never an integer. Let's say a common factor between x and y is a. We have [tex]\frac{xy}{a(\frac{x}{a}+\frac{y}{a})} = z[/tex]
In turn x/a and y/a need to have common factors for z to be an integer. If we have y > x and keep on and on, we eventually get to the point where
[tex]a_{1}*a_{2}* a_{3} *a_{4} *a_{5}... = x[/tex]
We conclude that y and x must have the same prime factors and that the number of times that a prime factor reoccurs in x is matched or surpassed by y. Now say y = kx, we have
[tex]\frac{xy}{x(1+\frac{y}{x})}[/tex]
[tex]\frac{y}{1+\frac{y}{x}}[/tex]
[tex]\frac{kx}{1+k}[/tex]
We can immediately see that 1 + k has to be a factor of x if z is to be an integer. Knowing that, we can construct an infinite number of pairs that satisfy the original expression; we need an y such as y = kx, and a x such that k+1 is one of its factor. For example, say k = 2, we can have x = (2+1)*7*5 and y = 2*(2+1)*7*5. So a solution is such as, if C and k are any positive integers, [tex]x = C(k+1), y = Ck(k+1)[/tex]
sorry, but i didn't understand some of your reasonings. for example,
why is that?
Just a hunch :-p I could be wrong. But the solution is valid for the case x and y have common factors. Also the kx/1+k thing is a hunch too.
There is something called, "Egyptian fractions." These are all the inverse of integers. It seemed that the Ancient Egyptians did not understand fractions except in the form of 1/N, and duplicates were not used. This system was even used by the Greeks for awhile, and results in very complicated things. Here is a simple formula that is useful: 1/N = 1/(N+1) + 1/((N+1)(N)).
Like say, we have the matter of 1= 1/3+1/3+1/3. We can expand this as: 1=1/3+1/4+1/12 +1/4+1/12 and finally: 1/3+1/4+1/12+1/5+1/20+1/13+1/156.
This then would have satisfied the Egyptian mathematicians of the day.
Some people believe there was SOME SENSE in this system. http://www.mcs.surrey.ac.uk/Personal/R.Knott/Fractions/egyptian.html#rhind
For example, suppose 5 sacks of grain are to be divided up by 8 people. Well we give each person 1/2 sack and then we take the remaining sack and divide it into 8 parts. Hooray! 1/2+1/8 = 5/8.
Werg22's method in the post#4 seemed really complicated and i didn't understand half of it. can anyone please check if there is any problem with this method:
if i put x = z+a and y = z+b, (where and b are integers) the equation becomes:
[tex]\frac{1}{z+a} + \frac{1}{z+b} = \frac{1}{z}[/tex]
[tex]\frac{2z + a + b}{z^2 + az + bz + ab} = \frac{1}{z}[/tex]
[tex]2z^2 + az + bz = z^2 + az + bz + ab[/tex]
[tex]z^2 = ab[/tex]
now we just have to factor z2. for example if the equation was
1/x + 1/y = 1/2007
we would put x = 2007+a and y = 2007+b and eventually get (2007)2 = ab. and then we just have to factor (2007)2 to find a and b.
IIRC you can do a coordinate rotation of [itex]\frac {\pi} 4[/itex] to see that this is a hyperbola. (This is just the thin lens equation with different variable names)
[tex]z^2 = ab[/tex]
1/x + 1/y = 1/2007
That's a good solution Murshid.
I had another solution that I didn't post. I won't post the details but I followed a similar path to werg to get it. In particular I assummed that x and y must have a common factor (something that at the time I couldn't really justify).
My solution was basically this. Let jk be factor of z. That is, z = ajk. Then
x = aj (j+k)
y = ak (j+k)
are solutions to your equation (1/x + 1/y = 1/z).
I like your solution a lot better. It was derived without the assumption of x and y sharing a common factor, though interestingly it can be used to prove that x and y must indeed have this common factor.
A rough proof that x and y (as per your solution) contain a non trivial common factor is as follows.
Let x = a + z and y = b + z,
where a and b are any factor pair of z^2
Since perfects squares must have all their prime factors in pairs, and since ab=z^2, then either a and b are themselves both perfect squares or they contain at least one common factor.
Case 1 : a and b are not perfect squares.
As above, a and b contain at least one common prime factor. Also z contains all the prime factors of z^2, so z shares the same common factors as a and b above (since z^2=ab). These common factors are thereofore also common factors of x and y.
Case 2 : a and b are both perfect squares.
In this case we just rewrite x and y as,
x = sqrt(a) (sqrt(a) + sqrt(b))
y = sqrt(b) (sqrt(a) + sqrt(b))
So clearly x and y have a common factor.
So the original hunch that x and y must have a common factor was indeeed correct.
31K
