What Is the Net Electric Field at the Midpoint Between Two Charged Particles?
The discussion revolves around calculating the net electric field at the midpoint between two charged particles, one negatively charged and the other positively charged, positioned on an x-y coordinate system.
  • Participants discuss the calculation of electric fields due to point charges and the need to consider unit vectors in the direction of the electric field. There are attempts to clarify the distances involved and the correct application of formulas.
Some participants are seeking clarification on the correct approach to determine the electric field at the midpoint, while others are questioning the assumptions made regarding distances and directions. There is an ongoing exploration of how to properly set up the problem.
Participants are navigating the complexities of vector notation and the specific distances from the midpoint to each charge, which may not have been clearly defined in the original problem statement.
threewingedfury
Two particles are fixed to an x-y coordinate system:
particle 1 of charge -5.00 microCoulombs lies on the x-axis at x = + 6.00 cm and particle 2 of charge +5.00 microCoulombs lies on the y-axis at y = + 8.00 cm. Midway between the particles, what is their net electric field, in unit vector notation?
So I got:
1/4piEo x q/r^2 - 1/4piEo x q/r^2
(1/(4pi(8.85x10^-12)) x (-5 x 10^-6)/(.06)^2)i - (1/(4pi(8.85x10^-12)) x (5 x 10^-6)/(.08)^2)j
-1.248e7i + 7024847j
Is this anywhere near right?
Not quite.
The electric field vector must point along the line from the positive charge to the negative charge, so one needs to determine the unit vector along that line.
The problem asks for the field at the midpoint between the charges, and so one needs the distance between the positive charge and the midpoint, and the negative charge and the midpoint. For one point at (x, 0) and the other at (0, y), think of (x/2, y/2).
so can anyone give me a better idea?
pretty please?
im a bit confused
So is it more like:
(1/(4*π*ε_0)*(5.00 μC / (3.00 cm)^2) for particle 1 and give it an 'i' and -1/(4*π*ε_0)*(5.00 μC / (4.00 cm)^2) for particle 2 and give it a j?
Since that's r/2?
  • · Replies 16 ·
