Maybe this is too simple 4 u guyz
  • Context: Undergrad
  • Thread starter Thread starter BrianT
The discussion revolves around a physics problem involving a mass on an inclined plane connected to another mass via a pulley system. Participants explore the mechanics of the problem, including the forces acting on the masses and the calculation of the angle of inclination. The context includes elements of homework, class dynamics, and the implications of solving the problem correctly.
  • Homework-related
  • Brian presents a physics problem involving a 10kg mass on an inclined plane and a 15kg mass suspended, asking for help to find the angle of inclination.
  • Some participants express confusion over the phrasing of the question, particularly regarding the term "volume of xº," suggesting it should refer to the angle instead.
  • One participant provides a detailed breakdown of the forces and equations involved, arriving at a proposed solution of 30 degrees for the angle.
  • Others discuss the ethics of helping with homework, with some arguing that students should do their own work to prepare for exams.
  • There are acknowledgments of the potential for mistakes in calculations, with one participant expressing confidence in their answer despite the possibility of error.
  • Participants share links to external resources for further assistance with similar problems.
  • There are expressions of gratitude towards those who contributed answers and support, highlighting a sense of community in the discussion.
Participants do not reach a consensus on the appropriateness of providing direct answers to homework questions. There is also disagreement on the interpretation of the problem's phrasing, with some focusing on the angle while others initially misinterpret it as volume.
Some participants note the lack of clarity in the problem statement and the potential for misinterpretation. The discussion also reflects varying levels of proficiency among participants, which influences their perspectives on homework assistance.
Students studying mechanics, educators looking for examples of student interactions, and individuals interested in the dynamics of physics problems involving pulleys and inclined planes.
BrianT
but we get off homework for 3 weeks if 1 of us gets the answer by 9 am on Monday! yippeee
A mass of 10kg lies on a smooth plane which is inclined at xº to the horizontal. The mass is 5m from top measured along the plane. One end of a light inextensible string is attached to the mass. The string passes up the line of greatest slope and over a smooth pulley fixed at the top of the plane. The other end is attached to a freely suspended 15kg mass. This mass is 4m above the floor. The system is released from rest, and the string first goes slack 1 and 3/7 seconds later
Find the volume of xº
any help will be greatly accepted!
Thanks
Brian
As for the question: Huh? Volume of x0?
As for whether or not anybody should answer the question: What do you have against homework? It's either do homework or do crappy on exams and have to do extra work to make-up the grade, no?
cookiemonster
Maybe you don't see it that way when youre 13 and the whole class is to get off -not just you=
But thanks anyway -Cool site, hopefully I'll be back again (when I get all my homework done heheeee
Cheers
BrianT
Well I'm not just going to answer someones homework unless I can IM them and get them to work it out step by step.
However here is a nice Website: http://www.mathsnet.net/ for maths help.
I do believe the sort of examples of questions that you want will be somewhere in this section: http://www.mathsnet.net/asa2/modules/m1.html
Also I think you mean the angle of x, not the volume.
Thnaks for those links! Much appreciated.
Just to clear up one thing.
- This test was NOT HOMEWORK - I do that myself all the time.
This was a question way ahead of what we are doing in school - which the teacher gave us on Friday.
and He said that if the right answer was in by Monday Morning - The whole class would get off Home work for 3 weeks
So my guess is that it must be a trick question cos that could never happen.
So I thought i'd ask you guys.
I'm in Derry in Ireland by the way and really say thanks for the answers
By the volume of x0 do you mean the angle? If so, after I finish my own homework I will put my hand to it, shouldn't be too hard.
Well i wrote it down a volume - but clearly it has to be angle/degree
Thnaks
I will check in - in the morning b4 school
but no worries if you can't - and mega thanks for even replying
go raibh míle maith agaibh
to you and all
Refer to the diagram where needed.
T-10gsinx=10a
T-15g=-15a
T=10gsinx+10a
T=15g-15a
10gsinx+10a=15g-15a
sinx=(15g-15a-10a)/(10g)
an aside to find a
t=10/7
4=at^2/2
8/t^2=a
a=8/(100/49)
a=98/25
plug a in
sinx=(15(9.8)-15(98/25)-10(98/25))/(10(9.8))
sinx=1/2
x=30 degrees
And that is the answer I got: 30 degrees
I did the work quickly though and there is a possibility I made a mistake, but with an answer that nice when taking into account 9.8 m/s^2 for gravity, I heartily doubt that I did
If you have any questions about how I got it, just ask.
edit: the diagram I made (a crappy one, though) was too large to attach. I merely made a right triangle of angle x, with a pulley at the other angle, the two attached blocks (the only important distance being the one block's 4 meters) and noted that only a portion of gravity pulls on the block.
And btw, since no information about it was given, I ignored all forms of resistance, and angular momentum.
cookiemonster
depends how proficient you are :) (in this case he should probably do his homework though)
Typically, the people that want to get out of homework are the ones that need it the most.
cookiemonster
Just want to say a sincere THANK YOU to Wooh for taking thetime and effort to reply.
You are a 'star'. Thanks again
cookiemonster got the wrong end of the stick entirely and obviuosly did not read correctly the earlier posts and sadly seemed a little bitter and the end of it all.
all should have the generocity of spirit of Wooh.
life is too short...
Did you get it correct? Did he accept? That's good, but I hope you understand HOW I did the problem, and you should still prep for tests!
As far as cookie goes, his point is a good one! Don't be naive, studying is important, and, especially as you gravitate closer towards your college experience, homework will become more about preparation than menial tasks which yield menial grades. You are doing him a disservice if you think he was meanspirited, more I think he simply meant that the kinds of people who most want to avoid homework, are the ones who could benefit from a bit of studying, but IMHO that is your choice to make, and if you DO blow the next 3 weeks because of this, learn from him! But I sincerely doubt that will happen, so kudos, understand the problem, and succeed.
It's nice when other people will defend you for you. Saves all sorts of work.
Thanks, Wooh.
cookiemonster
Thanks, Wooh.
cookiemonster
*academic high five*
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 68 ·
14K
