Does the expansion of spacetime affect gravitationally bound object?
The discussion revolves around the effects of the expansion of spacetime on gravitationally bound objects, specifically focusing on whether this expansion affects the distances between stars within a galaxy. Participants explore the implications of gravitational attraction in the context of cosmological expansion, examining both theoretical and observational aspects.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants propose that the gravitational attraction between stars in a galaxy negates the effects of spacetime expansion completely, while others suggest it merely diminishes the effects to undetectable levels.
  • It is noted that to observe the effects of expansion, one must look at galaxies beyond the local cluster, with examples like M31 being mentioned as blue-shifted relative to the Milky Way.
  • Some contributions reference the negligible effects of expansion on the solar system and galaxies, suggesting that under certain assumptions, such as dark matter leaving galaxies, there could be minimal changes in size.
  • A participant mentions that in a Schwarzschild-de Sitter space, the radius of a circular orbit remains constant over time, despite the expansion of space.
  • There are references to various sources and FAQs that discuss the topic, indicating that it has been addressed in other forums and literature.
  • One participant raises a question about the nature of de-Sitter space and its relation to the scale factor, which is confirmed by another participant.
  • Further technical discussions include the transition from "Sun dominated" to "Hubble dominated" forces in the solar system and the potential implications for phenomena like the Pioneer effect.
Participants express differing views on the extent to which gravitational forces counteract the effects of spacetime expansion, indicating that the discussion remains unresolved with multiple competing perspectives.
Some assumptions about the nature of gravitational binding and the conditions under which expansion effects are negligible are not fully explored, leaving room for further investigation.
arunma
Quick question on cosmology. As everyone knows, the expansion of spacetime increases the distance between galaxies. However, I'm wondering if the same expansion increases the distance between stars in any specific galaxy. I vaguely remember my cosmology professor saying that this does not happen since the stars in any individual galaxy are "graviationally bound" (but as I said I remember vaguely, so tell me if this is wrong).
So my question is: does the gravitational attraction between stars in our galaxy negate the effect of expansion completely, or merely diminish it so that it is not as easily detectable?
To notice any effect of expansion one must observe galaxies beyond our own local cluster. M31 for example is actually blue shifted wrt the Milky way. To find out the point between any two masses as to where the G force balances the stretching of space - you need to know the masses of the objects, and the separation distance.
I see. So then, the gravitational force can negate the effect of expansion. I think this answers my question, thanks a lot.
This has been discussed here before, but my favorite FAQ entery is http://www.astro.ucla.edu/~wright/cosmology_faq.html#SS
Basically, the effect on the solar system is negligible. The effect on galaxies is also unmeasurably small. The FAQ focuses on the solar system, though.
The case which maximizes expansion is the case when dark matter is assumed to be leaving the galaxies at some constant rate due to the expansion. You then basically have a tiny effect on the size of the galaxies due to the resulting mass loss.
If you make different assumptions, you can even get zero change in size of the galaxies due to the expansion. For instance, a circular orbit around a body in a Schwarzschild-De-sitter space does not change in radius as time progresses, even though the De-sitter space is "expanding" exponentially.
That's very interesting, thanks. Incidentally, perhaps you could refresh my memory. Is a De-Sitter space the one where the scale factor goes as eH*t?
Yep - that's the one. It arises when you have a cosmological constant.
If you have a de-Sitter space-time, and you have a single massive object in it, you have the Schwarzschild de-Sitter metric I was talking about.
See http://arxiv.org/abs/gr-qc/0602002v2 for more details.
If you put an object into a circular orbit in this space-time, the radius of the orbit is a constant - i.e. it's a true circular orbit, r does not change as a function of time.
Right, this is discussed in MTW and other standard sources. A good place to start, in fact, might be the FAQ http://math.ucr.edu/home/baez/physics/Relativity/GR/expanding_universe.html. This topic has been discussed in sci.physics.research at various times; until the past few years, this newsgroup (now largely overrun by cranks) was often a reliable source of information, so you can try http://groups.google.com/group/sci.physics.research/browse_thread/thread/7e26f7eb06749561/ and http://groups.google.com/group/sci.physics.research/browse_thread/thread/b4c8e98f4c5f8b6b/
In addition, see http://www.arxiv.org/abs/gr-qc/0508052 and
http://www.arxiv.org/abs/gr-qc/0612146.
The latter. Finding the locus where the transition from "Sun dominated" to "Hubble dominated" occurs for our solar system is a good exercise (see the paper by Price cited above). Another good exercise is to figure out whether this alone can account for the so-called Pioneer effect (assuming this has not be misinterpreted, or is not accounted for by even more mundane physics than the Hubble expansion).
About the Schwarzschild-de Sitter lambdvacuum: somewhere or other I have posted a very detailed analysis using effective potentials of test particle motion in this solution, including the issue of stability. Among other things, this affords a fun demonstration of using Sturm chains to analyse the disposition of real roots! There are also some arXiv eprints which carry out a similar analysis.
Getting a bit off topic, but here's another great exercise involving the de Sitter and Schwarzschild-de Sitter lambdavacuums: find as many "interesting" coordinate charts as possible and interpret the geometric/physical meaning of the coordinates.
  • · Replies 48 ·
  • · Replies 21 ·
  • · Replies 88 ·
10K
  • · Replies 23 ·
