Do Photons Gain Infinite Mass at Light Speed?
  • Level: Graduate
  • Thread starter Thread starter antariksh
    Light Mass Photons
66 replies · 12K views
antariksh
Just a thought, according to Einsteins relativity mass changes with speed and tends to become infnite as it approaches 'c'. Since photons too have mass, why doesn't their mass become infinite since they travel at c?
Photons have zero "rest mass", so that the Lorentz transformation can't be used - ie. m= (0/0)*c2.
Rather than the phrase "rest mass", it might be more appropriate to use the term "invariant mass" or (up to factors of c) "invariant norm of the momentum 4-vector". With this term, then it is easier to see that one can apply the Lorentz Transformation to the photon's [necessarily non-timelike] 4-momentum.
One sees that its square-norm being zero is true in all inertial reference frames. In addition, its temporal component is essentially the relativistic energy (up to constants, the frequency) of the photon. Similar to the "relativistic mass" (or better, up to constants, "relativistic energy"), the relativistic energy of the photon can be boosted toward infinity. (Of course, the "factor" is different... for the photon, it is "k" (the doppler factor), which is [tex]\gamma(1+v)[/tex].)
Of course, what you can't do is to boost from the frame of a timelike particle (where that particle is at rest) to one for a null (or lightlike) particle.
That's not the Lorentz transformation. The Lorentz transformation equations for position and time are
[tex]x^\prime = \gamma (x - vt)[/itex]<br /> <br /> [tex]t^\prime = \gamma \left( t - \frac {vx}{c^2} \right)[/tex]<br /> <br /> for position and time, and<br /> <br /> [tex]p^\prime = \gamma \left( p - \frac {vE}{c^2}\right)[/tex]<br /> <br /> [tex]E^\prime = \gamma (E - vp)[/tex]<br /> <br /> for momentum and energy. As far as I know, they are valid for light (photons) as well as for particles with nonzero "rest mass".[/tex]
photon momentum and energy is a frequent topic on the forum. consider a tardyon (u<c) the momentum of which transforms as
p=gp'(1+V/u') (1)
E=gE'(1+Vu'/c^2) (2)
state that special relativity theory ensures a smooth transition from the properties of the tardyon to the properties of a photon and make in (1) and (2) u=u'=c in order to obtain in its case
p(c)=gp'(c)(1+V/c) (3)
E(c)=gE'(c)(1+V/c) (4)
Is there more to say?
sine ira et studio
p=gp'(1+V/u') (1)
Doesn't look correct. Here are the correct ones.
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/vec4.html
For the photon you can further simplify the above by using the fact that energy and momentum are related by [tex]E=c*\sqrt<p,p>[/tex].
We are not sure that light has zero rest mass or that it travels 100% of the speed of light.
But we do know it is very close to it. Make that very very close.
Light does not travel at the speed of light? Then why do you call it "the speed of light"? :rolleyes:
Is 99.9999999999 equal to 100?
No it isn't, but can you tell? That is the point.
If a person is accelerated to 99% of the speed of light and that person measures the speed of the photon passing him he will determine the photon is traveling past him at the speed of light.
So if two photons are traveling in parallel paths what speed do they measure of each with respect to the other?
or, looking at it another way, instead of mapping rest mass to "relativistic mass" (or "inertial mass" or whatever it is you get when you divide momentum by velocity),
[tex]m = \frac{m_0}{\sqrt{1 - \frac{v^2}{c^2}}}[/tex]
map it back the other way:
[tex]m_0 = m \sqrt{1 - \frac{v^2}{c^2}}[/tex]
so, if the photon has a finite inertial mass
[tex]E = m c^2 = h \nu[/tex]
or
[tex]m = \frac{E}{c^2} = \frac{h \nu}{c^2}[/tex]
and the momentum is
[tex]p = m v = \frac{h \nu}{c^2} v[/tex]
but if the velocity of the photon is [itex]c[/itex], then
[tex]p = m c = \frac{h \nu}{c}[/tex]
no matter what that finite value is, the rest mass (or "invariant mass") is still zero when [itex]v = c[/itex].
[tex]m_0 = m \sqrt{1 - \frac{c^2}{c^2}} = m \sqrt{1 - 1} = 0[/tex]
that's my oversimplistic spin on it.
The speed of light is, well, the speed of light. If you think that photon travel at 0.999999999999c where c is the current value of the speed of light, we can just define the "correct" speed of light as c'=0.999999999999c. :smile:
of light.
Photons don't experience time, and thus they can't measure speed. The closest thing to "experiencing time" is that photon geodesics can be parametrized in terms of an affine parameter, which however is neither like time (timelike) nor like space (spacelike), but null.
There are a number of FAQ's and threads on this
http://math.ucr.edu/home/baez/physics/Relativity/SpeedOfLight/headlights.html
https://www.physicsforums.com/showthread.php?t=132528
and there's a lot more I've skipped over, including one by robphy that was particularly good that I can't find.
You are correct pervect
For this reson if a photon has zero rest mass it may also be an unstable energy unit but without the time to decay for certainly it would have decayed in billions of years of travel if it contained a time component.
As to the light speed.
If a photon has a rest mass particle then it can not attain a speed of C but will only attain a velocity of C ‘ which is slightly less then the theoretical speed of light C.
In this case the measured speed of light is C ’ and the true speed of light C must be calculated or by other means to be known.
The photon must also be a stable energy unit to prevent decay.
the quantity we call [itex]c[/itex] is the wavespeed of electromagnetic propagation in a vacuum that you get from solving Maxwell's Equations. you know:
[tex]c = \frac{1}{\sqrt{\epsilon_0 \mu_0}}[/tex]
it would be more precise to say that "We are not sure that photons have zero rest mass or that they travel at 100% of the wavespeed of light." BTW, this was something totally new to me a year ago. i still have trouble believing it. (there is the aesthetic part of me that wants the dogma that the speed of photons are [itex]c[/itex] which means they must have zero rest mass.)
Interestingly C was defined by definition in 1983.
Permittivity (E)of free space is defined by C and the Maxwell equations.
Permeability (u) is measured.
Which means C can not be determine by ( or is not determined ?) by the Maxwell equations.
Unless (E) can be measured.
http://en.wikipedia.org/wiki/Speed_of_light
Correct, as per wiki:
"In metric units, c is exactly 299,792,458 metres per second (1,079,252,848.8 km/h). Note that this speed is a definition, not a measurement. Since the fundamental SI unit of length, the metre, has been defined since October 21, 1983 in terms of the speed of light; one metre is the distance light travels in a vacuum in 1/299,792,458 of a second."
You may wonder why is c defined and not measured to be 299,792,458 metres per second .
The reason is that any physical measurement has certain error attached to it, so that a number had to be chosen. To recap:
1. c is chosen
2. [tex]\epsilon_0[/tex] is defined based on c
3.[tex]\mu_0[/tex] is derived based on the values chosen at 1 and 2
So, all of the above guarantees that c is exactly 299,792,458
1. c is chosen
Actually the reason c is a constant has to do with how the meter is defined.
It's worth noting that the definitions of SI (MKS) units are made for practical reasons. They are intended to permit the most precise measurements possible, with the current state of technology.
Before 1983, the second was defined in terms of the period of a certain atomic transition, and the meter was defined in terms of the wavelength of another atomic transition. Those definitions were made because they could be reproduced in laboratories with the highest degree of precision possible at the time.
At some point, measurements of the speed of light became intrinsically more precise than the precision of the definition of the meter. Since there was (and still is) no experimental indication that the speed of light is not constant, defining the meter in terms of a constant, defined value of the speed of light maximizes the precision of measurements overall.
If at some point the speed of light is shown not to be constant, then the definition of the meter will surely be changed to reflect this.
Actually, that need not necessarily be the case.
A second is defined using the frequency of Cs atoms right now. However, we know that the period of time is frame dependent (i.e. Cs atom in another frame would not have the same frequency). Yet, we still use this as our standard definition of a second.
So based on this, I think we can still use c to define a meter, even if we find (a very big if) situations where it isn't a constant. We just have to clearly define under what conditions this definition is to be used, just like most of our other constants.
Zz.
Interesting thoughts
Because the terms are defined from one another it is impossible to determine if indeed light photons have slightly slower velocity then a theoretical maximum mass speed of light C.
It would be interesting to use the plank constant values to determine the minimum size of a mass particle and accelerate the mass until it had a photon equivalent relativistic mass.
The percentage of the speed of light the photon would achieve could then be calculated.
Different wavelengths would mean different relativistic mass quantities and different velocities however small these velocities differences may be.
It would be interesting to calculate the difference in velocity to determine if the velocity difference is measurable.
The effect would cause different wavelengths from a distant star to reach us with time delays.
Does anyone know if a pulsar has been checked to see if the lower and higher wave lengths are received without a time delay when viewed at the greatest distance possible?
If one photon had one smallest mass particle it would cause a quantum condition because photons could only have a whole number of smallest mass particles.
c is constant by definition in relativity. In addition, there is ample experimental confirmation, so I don't think that c being a constant has much if anything to do with the meter is defined.
Actually, it is exactly the other way around, the definition of the meter is dependent on c:
http://en.wikipedia.org/wiki/Meter
and on the definition of the second.
nakurusil said:
I do not think so.
That is fine, and you seem to be hard to convince , so I won't bother. :smile:
For others, the meter is defined in terms of the speed of light. One meter is the distance traveled by light in a vacuum in 1/299,792,458 of a second. So obviously c must be 299,792,458. :smile:
Check my post.
nakurusil said:
I don't think so.
he must have deleted that post, because i was about to tell him to check it out at the NIST site if he doesn't believe it.
some of the other stuff he said (like [itex]\mu_0[/itex] being derived) is not correct either.
nakurusil said:
Check my post.
what's there to check? you said two things that are demonstratively incorrect. check the NIST site to see how these get defined so that c = 299792458 m/s. and how [itex]\mu_0[/itex] is defined, not derived.
Look at "Overview" here:
[tex]mu_0[/tex] value is chosen such that [tex]1/\sqrt(\epsilon_0mu_0)=299,...[/tex]
