Is the Velocity of Water at the Top of a Glass Really Zero?
  • Thread starter Thread starter Gyroscope
    Glass Water
The discussion revolves around the velocity of water at the top of a glass, particularly questioning whether it is truly zero. Participants explore the implications of this assumption in the context of fluid dynamics and Bernoulli's equation.
  • The original poster attempts to understand the reasoning behind considering the velocity at the top of the glass as zero, despite the random motion of water molecules. Other participants discuss the implications of making a hole in the bottom of the glass and how it affects the velocity of the water at different points.
Participants are actively engaging with the concepts, questioning the assumptions made about the velocity of water at the surface and its relationship to the flow rate when a hole is introduced. Some guidance has been offered regarding the conditions under which the velocity can be considered zero.
There is an emphasis on the conditions of the problem, such as the size of the hole and the height of the water, which may influence the assumptions being discussed. The original poster references textbook exercises that relate to these concepts.
Gyroscope
What is the velocity of the water at the top of a glass of water? Is it really 0?
For example, there is a lot of problems which asks with what velocity does the water would leave that glass if I make a hole on the bottom. For these, we consider the velocity at the top to be zero. Why is that? Is it approximately zero or really zero? I am thinking now, if it is an incompressible fluid, it must be zero, because if the water is confined to that volume, cannot have speed. Nevertheless, it is clear that the water molecules are randomly moving. Can you clarify my doubts? Thanks in advance.
When there is no hole in the bottom of the glass, the velocity of all of the water is zero. When there is a hole suddenly made in the bottom of the glass that goes all the way across (hole diameter = glass diameter), all the water accelerates together down out of the glass, and the velocity of the top surface is the same as the velocity of the bottom surface (ignoring the wetting effects on the walls).
When there is a hole in the bottom that is smaller than the diameter, then the flow rate out the hole will determine how fast the top surface goes down (through volume change calculations).
I had an exercise on my book where I should show that the velocity at the bottom of the glass where there is a small hole is [tex]\sqrt{2gh}[/tex], h is the height of the water level. This is only true, if I consider the velocity at the surface to be zero, when applying Bernoulli's equation. Right?
which it will nearly be if the hole is relatively small.
  • · Replies 42 ·
  • · Replies 21 ·
9K
  • · Replies 32 ·
