Integral of Secant: Solving for \int \frac{1}{cosx} dx | Step-by-step Solution
  • Thread starter Thread starter Sisyphus
    Integral Secant
The discussion revolves around finding the integral of the secant function, specifically \(\int \frac{1}{\cos x} dx\). Participants explore various approaches to solving this integral and address issues encountered during differentiation of their results.
  • The original poster attempts to solve the integral by manipulating the integrand and substituting variables. Some participants question the implications of a negative sign in the substitution process and its effect on the integration steps.
Participants are actively discussing the integration process and the significance of the negative sign in the substitution. Some guidance has been offered regarding the correct handling of the negative sign, and there is recognition of the need to adjust the integration approach accordingly.
There is mention of confusion regarding the standard result for the integral of secant, with some participants expressing surprise at the method being discussed. The original poster's attempts and the feedback received highlight the complexities involved in the integration process.
Sisyphus
Basically, I have to find
[tex] \int \frac{1}{cosx} dx [/tex]
by multiplying the integrand by [tex]\frac{cosx}{cosx}[/tex]
I go through and arrive at a solution, but when I differentiate it,
I get -tan(x)
something's clearly wrong, but I can't see what it is that I'm doing wrong here...
[tex] let u = sin(x)[/tex][tex]du = cos(x)dx[/tex]
[tex] \int \frac{1}{cosx} dx = \int \frac{cosx}{cos^2x} dx\\<br /> = \int \frac{cosx}{1-sin^2x} dx\\<br /> =\int \frac{du}{1-u^2} \\<br /> =\int \frac{du}{(1-u)*(1+u)} \\<br /> =\frac{1}{2} * \int \frac {1}{1+u} + \frac {1}{1-u} du\\<br /> = \frac{1}{2} * (ln(1-u^2}}) <br /> =\frac{1}{2} * (ln(cos^2))[/tex]
Your second to last step (where you actually perform the integration) is wrong. In the second term, remember that u has a minus sign.
hmm..
I've never run into anything like this before
so why does u having a minus sign in front of it pose a problem with what I did in my original solution?
(thanks for the help)
Well, the value of your integral will be ln(1+u)-ln(1-u)
if I kept the minus sign where it was, which is what I did in my original solution, my integral would've been
[tex]ln(1+u)+ln(1-u)=ln(1-u^2)[/tex]
StatusX told me to watch out for the negative sign in front of the u, so I factored it out, made sure that u was positive, and then integrated it, which gave me the correct solution.
the thing is I'm not sure why I couldn't proceed as usual with the minus sign in front of the u
StatusX said to note the minus sign in front of the u. You can proceed as normal, but noting that [tex]\int\frac{1}{1-u}du=-ln(1-u)[/tex]. In general [tex]\int\frac{1}{f(u)}du=\frac{ln[f(u)]}{df/du}[/tex]. In this case, f(u)=1-u, and so df/du=-1
ah, ok
thank you!
o_O i didn't know we would utilizie such a method to do this integral.
i've always thought the integral of secant was just sec[x]tan[x]!
That's the derivative of sec(x)
  • · Replies 105 ·
13K
  • · Replies 22 ·
