Solving Change of Variables for Triangular Region
The discussion centers on evaluating the double integral ∫∫f(x+y)dA over a triangular region defined by the vertices (0,0), (1,0), and (0,1). The user seeks to demonstrate that this integral is equivalent to ∫∫uf(u)du. Key insights reveal that the triangular region's boundaries are x=0, y=0, and x+y=1, with the transformation x+y=u leading to u=1 and u=0. A critical point raised is the need to clarify that dA represents an area differential, and the correct formulation should involve ∫∫uf(u)dudx.
  • Understanding of double integrals in calculus
  • Familiarity with change of variables in integration
  • Knowledge of triangular regions and their properties
  • Basic concepts of differential area elements in multivariable calculus
  • Study the method of change of variables in double integrals
  • Learn about the properties of triangular regions in integration
  • Explore the relationship between area differentials and variable transformations
  • Investigate examples of evaluating double integrals using different coordinate systems
Students and professionals in mathematics, particularly those studying calculus, multivariable integration, and anyone looking to deepen their understanding of change of variables in integrals.
bodensee9
I am wondering if someone could help me with the following? I am supposed to show that ∫∫f(x+y)dA evaluated from the triangular region with the vertices (0,0), (1,0) and (0,1) is equal to ∫∫uf(u)du.
This triangular region has the equations, x = 0, x = 1, and y = -x + 1. If I set x+y = u, then I know that u must satisfy the equations u = 1, u = 0. But, I’m not sure what to do after that? If someone could give me some hints, that be great. Thanks!
No, the triangular region has boundaries x= 0, y= 0, and x+ y= 1. The upper line, x+ y= 1 corresponds to u= 1 but neither x=0 nor y= 0 corresponds to u= 0. In any case, your problem is incomplete. ∫∫f(x+y)dA is a double integral. In ∫∫uf(u)du du is not an area differential. Did you mean show that it is equal to ∫∫uf(u)dudx? If so then the limits of integration are irrelevant. You need only show that dA= dydx= ududx. for some choice of u.
  • · Replies 16 ·
