| Thread Closed |
area between curves |
Share Thread |
| Feb3-07, 07:21 PM | #1 |
area between curves
Find the area of the region bounded by: y=cosx, y=sin2x, 0, x=pi/2 2. Relevant equations 3. The attempt at a solution I made a graph. I believe I'm trying to find the area I shaded. red=cos(x), blue=sin(2x) I need to find the intersection point so I will know the limits of my 2 integrals. cosx = sin2x But I don't know how to do this. There should be an infinate number of intersections, but I am only interested in the one that appears to happen around x=1/2 and the next one at what appears to be pi/2. I can verify with my calculator that cos(pi/2) and sin(2pi/2) both equal 0, and that the right limit given by the problem is indeed the intersection, but that is not the case for the 1st intersection. How do I solve this? And what if the book gave the right limit as x=2. My method of eyeballing it and verifying my guess with the calculator would fail. Assuming I find the intersection point, the next thing I was going to do is: [tex]\left( {\int_0^{???} {\cos x} \,dx\, - \,\int_0^{???} {\sin 2x} \,dx} \right)\, + \,\,\left( {\int_{???}^{\pi /2} {\sin 2x\,dx} - \int_{???}^{\pi /2} {\cos x\,dx} } \right)[/tex] 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Feb3-07, 08:56 PM | #2 |
Recognitions:
sin(2x)=2 sinx cos x
cos x= 2sinx cos x 1=2 sin x sin x =1/2 So the solution is arcsin (1/2). What value of sin x gives us 1/2? pi/6 of course. Thats the systematic way of doing it, you may also have done cos x= sin (pi/2 -x) so equate them, sin (pi/2 - x)=sin 2x, 2x=pi/2 - x, 3x=pi/2, x=pi/6. The 2nd way is only useful for angles less than pi/2, which means it can be used here. Now that you have both intersection points just integrate as how you were going to do next, knowing the ???'s is pi/6. |
| Feb3-07, 09:11 PM | #3 |
Thanks for your reply.
sin(2x)=2 sinx cosx I guess that's just a trig identity I forgot? Playing with it on my calculator, I can see that it works for all values of x. cosx = 2 sinx cosx Playing with this on my calculator, it does not work for all values of x. Is this a trig identity, or specific to this problem? If specific to this problem, from sin(2x)=2 sinx cosx i get cosx = sin(2x)/2sin x How did you get cosx = 2 sinx cosx ? |
| Feb3-07, 09:16 PM | #4 |
Recognitions:
area between curves
Sin 2x = 2sinx cos x is a identity you just forgot.
Cos x= 2sinx cos x is specific to the problem. When we want to find points of intersection, we set the 2 functions to be equal, then solve. The functions we have are sin 2x and cos x. Since sin 2x=2sinx cos x for all x, we sub that in, then we have to solve cos x=2sinx cos x. I dont know why you got cos x= sin(2x)/2 sin x, thats not needed. cos x = 2sin x cos x Divide both sides by 2 cos x, sin x=1/2. Solving for that, arcsin 1/2=pi/6 |
| Feb3-07, 09:19 PM | #5 |
Recognitions:
The Indentity can be easily seen from expanding the formula for sin(x+y), letting y=x.
| Thread Closed |
Similar discussions for: area between curves
| Area between 2 curves | Calculus & Beyond Homework | 2 | ||
| area between two curves | Calculus & Beyond Homework | 8 | ||
| Area Between Curves | Introductory Physics Homework | 5 | ||
| Area between two curves | Calculus | 14 | ||
