Max EMF Induced in AC Generator?
The maximum electromotive force (emf) induced in an AC generator with an armature rotating at 30 revolutions per second in a magnetic field of 1.0 Wb/m² is calculated to be 543V. The armature has a diameter of 24 cm and a length of 40 cm, resulting in a total area of 0.096 m² per loop. The calculation involves determining the magnetic flux rate using the formula dA/dt * B, where the area is modeled as a sine function due to the rotation. The discrepancy in the expected emf value arises from the need to account for the area of the rectangular loops rather than just the circular area.
  • Understanding of electromagnetic induction principles
  • Familiarity with AC generator operation
  • Knowledge of calculus for deriving magnetic flux rates
  • Basic understanding of angular frequency and its calculations
  • Study the principles of electromagnetic induction in detail
  • Learn about the design and operation of AC generators
  • Explore the calculation of magnetic flux and its applications
  • Investigate the effects of different armature designs on induced emf
Students studying electrical engineering, physics enthusiasts, and professionals involved in generator design and optimization will benefit from this discussion.
pivoxa15
The armature of an AC generator is rotating at a constant speed of 30 revolutions/second in a horizontal field of flux density 1.0Wb/m^2. The diameter of the cylindrical armature is 24cm and its length is 40cm. What is the maximum emf induced in the armature having 30 turns?
emf=-magnetic flux rate although this problem is more about magnitude
The generator is rotating at 0.033seconds/period. The area facing the magnetic field follows a sin curve. The full area is (0.12m)^2*pi=0.045m^2 The sine curve has angular frequency b given by 2*pi/b=0.033seconds/period. So b=188.5 Hence the area is given by 0.045m^2*sin(188.5t)
The magnetic flux rate is dA/dt * B
dA/dt =0.045m^2*188.5*cos(188.5t)=8.48*cos(188.5t)
max magnetic flux rate = 8.48*30 = 254.5V which includes the 30 turns. The answer stated 543V. Why?
When doing the problem I have not used the length of the cylindrical armature which stands at 0.4m. I don't know where I could use it.
The cylindrical armature is spinning on its long axis and the wire is wrapped in square loops around its length each measuring 24 x 40 cm. So each loop has an area of .24x.4 = .096 m^2.
AM
So the wires are not wrapped around in circles but in rectangles with an area vector perpendicular to the 2 circlular faces of the cylinder. In fact the area vector of the 2 circular faces act as the axis of rotation and the area vector of the rectangle formed by the wires spin in a circlee and come back to the same position every 360 degrees.
