Can You Calculate the Electric Field of a Charged Sphere Using Disc Integration?
The discussion revolves around calculating the electric field of a uniformly charged sphere by utilizing the electric field of a charged disc. Participants explore the integration of contributions from infinitesimally thin discs that make up the sphere.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the expression for the electric field due to a charged disc and the challenges of integrating over different coordinates. Questions arise regarding the appropriate volume element to use for the discs and the implications of using spherical versus cylindrical coordinates.
There is an ongoing exploration of different coordinate systems and their suitability for the problem. Some participants express confusion over the volume element for the discs, while others suggest using cylindrical coordinates as a more fitting approach. No consensus has been reached, but various perspectives are being considered.
Participants note that the problem is complex and not typical of standard homework assignments, indicating a higher level of difficulty. There is also mention of the symmetry of the problem influencing the choice of coordinates.
Kolahal Bhattacharya
To find the electric field of a uniformly charged sphere at some distance using the result of the field at an axial of a charged disc.
Well,I approached this proble m in the following way:
You may verify that
E’=(σz’/2ε)[(1/z’)-{1/√(z’^2+r’^2)}is the expression for electric field at an axial point due to the charged disc. We use primed co-ordinates to any such disc located at an arbitrary place in the sphere. z axis is taken vertical, r’ is the radius of a disc.
Now consider the sphere to be made up of such charged discs, in succession; i.e. one placed on another and so on. For a very large number of discs, we may assume contribution from each disc to be dq and in that case, it is easier to think of a volume charge density ρ distributed all over the volume.
Then, dE={(dq/πr’^2)z’/2ε}[1/√(z’^2+r’^2)]
Putting z’=(z-Rcosθ) and r’=Rsinθ in the expression we get a formidable expression. However, dq has not yet been replaced. We Should replace it with ρ dV where dV is the standard volume element in spherical polar co-ordinates.
Now, the problem is how to evaluate the integration. Ф integration is not a problem. Θ integration is bizarre. What about radial co-ordinate integration? I thought only ∫dV will suffice. My friend says that each and every R over here: dq/πr’^2 and over here: [1/√(z’^2+r’^2)] are to be integrated.
I will simply die then.
However, it’s not any homework problem as you could easily see from its level of difficulty. I thought there should exist a way to approach in this path.
I think this is incorrect. Since the infinitesimal charge is contained in the thin disc, the infinitesimal volume should be the volume of the thin disc, and not the standard volume element in spherical polar co-ordinates.
Then how would you proceed?A thin disc has no volume.And if you think of a pillbpx like thing,then what would be the appropriate volume element?
The thin disc, or cylinder, should have an infinitesimal height [itex]dh=R d\theta[/itex]. So, the corresponding volume would be [tex]\pi R^2 \sin^2 \theta R d\theta[/tex]
However,thank you for replying.It's done,not in your way.I used cylindrical co-ordinates all the way,as per the demand of the problem.Use volume element dV=(pi r'^2)dz' and r'+sqrt(R^2-z'^2) and also the distance upto the point from the centre is (z-z').
I think spherical polar co-ordinates will be a little bad choice to do it.The symmetry is not spherical
Just to clarify, I didn't use the standard volume element in spherical polar coordinates for this question. Since the field of the disc is know, simply sum up the field due to the infintesmally thin disks over the z axis
So, what I did was to reduce the integral to one variable (ie, theta), and integrate over that variable.
