Why is the electric field intensity zero at only one point?
The discussion revolves around the concept of electric field intensity (EFI) in the context of two point charges: a 2μC charge and a -8μC charge positioned on a Cartesian coordinate system. The original poster questions why the EFI is zero at only one specific point, (-4,0), and not at other points along the x-axis.
  • Participants explore the mathematical representation of electric field strength and question the behavior of electric field lines. There is an inquiry into the nature of the electric field and its representation through field lines, as well as the conditions under which the EFI reaches zero.
The discussion is active, with participants providing mathematical reasoning and questioning the conceptual understanding of electric fields. Some guidance has been offered regarding the vector nature of electric fields and the conditions for cancellation at specific points.
Participants are considering the implications of charge placement and the resulting electric field behavior, while also acknowledging the limitations of visual representations of electric fields without computational tools.
imranq
Suppose you have a Cartesian coordinate system with:
a 2uC charge at (0,0) and a -8uC charge at (4,0), why is there only one point in which the EFI is zero (-4,0)? Shouldn't that be the first point where the EFI is zero (so (-5,0),(-6,0)... all have Electric Fields of zero)
The reason I think this is because if you drew the Electric field lines from one charge to the other, they wouldn't go either way infinitely.
Thanks
Electric field strength is zero only at (-4,0) because field strength are given by (up to a multiplicative constant)
[tex]\displaymath{\frac{q}{r^2}}[/tex]
so at (-4,0)
you have
[tex]\displaymath{\frac{2}{4^2}+\frac{-8}{(4+4)^2}=<br /> \frac{2}{16}-\frac{8}{64}=0}[/tex]
whereas at (-5,0) you get
[tex]\displaymath{\frac{2}{5^2}+\frac{-8}{(5+4)^2}=<br /> \frac{2}{25}-\frac{8}{81} \neq 0}[/tex]
I know that, but can you explain the field itself, since drawing the electric field lines doesn't seem to explain this
it is very hard to draw field lines to explain this, you will need a computer to help to do this properly. mind you an E-field is a vector field and at each spacetime point it has a magnitude and direction, so strictly speaking, to draw this properly you need to insert at each point a little vector, do this for each charge separately and you will find that only at (-4,0) will the magnitude be the same AND direction is opposite (ie cancel after doing the vector sum)
  • · Replies 22 ·
