Calculating Tension Life of a Spring
  • Thread starter Thread starter araanandv2
    Life Spring
The discussion focuses on calculating the tension life of a spring used in a valve application. To determine the duration for which the tension remains constant, one must reference a fatigue life chart specific to the spring's material, which plots fatigue life against stress. If the operational stress is below the curve, the spring can theoretically last indefinitely; if it intersects the curve, failure will occur after a specified number of cycles. For detailed methodologies, consulting resources in Mechanical Design or Theory of Machines is recommended.
  • Understanding of fatigue life and stress analysis in materials
  • Familiarity with Mechanical Design principles
  • Knowledge of spring mechanics and applications
  • Access to material science resources for fatigue charts
  • Research fatigue life charts for specific spring materials
  • Study Mechanical Design textbooks for formulas related to spring tension
  • Explore the Theory of Machines for advanced spring calculations
  • Learn about stress analysis techniques in material science
Mechanical engineers, materials scientists, and anyone involved in the design and analysis of spring mechanisms in engineering applications.
araanandv2
hi,
Our counterparts have designed a spring for a valve application.
the entire component depends on the tension of the spring
We need to calculate the tension life of a spring(i.e the duration for which the tension in a spring remains a constant)
Please provide me a solution
Thanks
You need to find a chart of the material the spring is made out of that graphs the fatigue life vs. the stress. If your stress falls under the curve, it will last forever. If it intercepts the curve, it will fail at N-cycles.
Astronuc can give you a better explanation. Thats a question for Material Science section.
try finding books of Mechanical Design subjects, or Theory of Machines. they usually contain such answers, they are long formulas with many many variables sometimes more than 8 variables that depend on the materials and applications of the spring. good luck
14K
