How Does Thrust Affect the Weight Calculation of a Spacecraft on Planet X?
The problem involves a spacecraft descending on Planet X, where varying thrust levels affect its acceleration. The original poster seeks to determine the spacecraft's weight by applying Newton's second law in two scenarios: one where the thrust slows the descent and another where it accelerates upward.
  • Participants discuss the relationship between thrust and acceleration, questioning the implications of different thrust values on the spacecraft's motion. The original poster expresses confusion about the outcomes of the thrust values and their calculations. Others suggest developing equations based on net acceleration and gravitational force.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the formulation of equations to relate thrust and gravitational pull, but no consensus has been reached on the correct approach or solution.
Participants note the problem's wording may be unclear, which could impact understanding. There is also a mention of needing to derive equations with two unknowns, indicating potential complexity in the calculations.
Peach
A spacecraft descends vertically near the surface of Planet X. An upward thrust of 25.0kN from its engines slows it down at a rate of 1.20m/s^2, but if an upward thrust of only 10.0kN is applied, it speeds it up at a rate of .80m/s^2. Apply Newton's second law to each case, speeding up or slowing down, and use this to find the spacecraft 's weight near the surface of Planet X.
F = ma
Okay, I'm confused about how if 25.0kN force is applied, then it slows down but 10.0kN part will speed it up. I guess maybe that's why my method is wrong and I keep getting the wrong answer. This is what I'm doing: since I have the force and acceleration, I converted kN to N and divided by its acceleration to find the mass. Then I take the mass x gravity = weight, converting it back kN. Pls help me, where did I go wrong?
Another poorly worded problem if that's quoted accurately. Is the right answers 2.13(7500)=15975?
Yeah, I copied it word for word. I don't have the right answer but um, how did you get those numbers?
well what the question supposes(and its poorly worded) is "it" is the planets gravitational pull. In one case it retards the spacecraft s upwards acceleration so that the net acceleration is up, and in the second case the gravitational pull overcomes the thrust of the rocket. In each case, try to develop an eqn for the given net a in terms of the rocket thrust and unknown g constant of the planet. Should have 2 eqns, 2 unknowns.
Ah, if you didn't explain, I don't think I'd understand the problem...I got it now, thank you very much.
My pleasure, I just can't resist a rocket problem!
John
  • · Replies 25 ·
15K
10K
  • · Replies 22 ·
  • · Replies 18 ·
