What Is the Magnetic Field Between Two Parallel Wires Carrying Current?
  • Thread starter Thread starter nautica
The discussion revolves around calculating the magnetic field between two parallel wires carrying current, as well as understanding the properties and units of magnetic fields and electromotive force (emf). The subject area includes electromagnetism and magnetic field theory.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of the magnetic field between two wires, questioning the application of formulas and the consideration of current directions. There are also inquiries about the units of magnetic fields and emf, with some participants expressing uncertainty about specific options.
Some participants have offered guidance on the calculations and the importance of considering directions in the magnetic field formula. There is ongoing exploration of the correct answers to the unit-related questions, with no explicit consensus reached on the final outcomes.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is a noted confusion regarding the choices available for the units of magnetic fields and emf.
nautica
I feel pretty confident in the rest of the problems and am down to these. I appreciate the help.
16) 2 long straight wires are parallel and carry current in the same direction. the currents are 8 A and 12 A and separated by 0.4 cm. The mag field in tesla at a point midway between the wires is?
I used B=uI/2(pie)r but did not come up with the right answer.
20) a uniform magnetic field is directed into the page. A charged particle, moving in the plane of the page, follows a clockwise spiral of decreasiing readius. An explanation would be.
My answer is: the charge is poistive and slowing down
21) electrons are going around a circle in a counterclockwise direction. At the center of the circle they produce a magnetic field that is:
My answer: out of the page
24) 2 parrallel wires, 4 cm apart, carry currents of 2 A and 4 A respectively, in opposite directions. The force per unit length on of one wire on the other is:
4 x 10^-5 attractive
26) Units of magnetic field might be:
a) C m/s
b) C s/m
c) C/kg
d)kg/C s
e) N/C m
23) The units of motional emf are:
a) volt/second
b) volt meter/second
c) volt/tesla
d) tesla/second
e) tesla meter^2/second
I don't have a clue on 23 or 26
thanks
nautica
for P16 u need to consider directions as well it would be difference of the 2
i.e {uI1-uI2}/2 r
i.e {uI1-uI2}/2 r
If I subtract the 12 - 8 I get 4 so
(4pi x 10^-7) x 8 / 2pi x .004 = 2 x 10^-4
this is not a choice, these are the choices
a) 0
b) 4 x 10^-4
c) 8 x 10^-4
d) 12 x 10^-4
e) 20 x 10^-4
Note concerning units
U know various formula now look for pro 26
what does option a represents charge*velocity but there is no such formula for magnetic field which corresponds to it
Now for option e Force/{charge*length} which correspond to formula
F=q{dl*B}
for pro 23
emf = BdA/dt= T*m^2/s
a) 0
b) 4 x 10^-4
c) 8 x 10^-4
d) 12 x 10^-4
e) 20 x 10^-4
u are doing calculation error it should be 16/4=4*10^-4
  • · Replies 46 ·
9K
