How to interpret physically the divergence of vector field?
The discussion centers around the interpretation of the divergence of a vector field, particularly in the context of fluid mechanics and electromagnetism. Participants explore how divergence relates to physical concepts such as fluid flow and electric fields, with specific reference to Gauss' Law and charge density.
  • Some participants express difficulty in visualizing the concept of divergence, particularly its application to electric fields and charge density.
  • One participant suggests that the divergence of an electric field indicates how much the field is "spreading out" from a point, implying a relationship to sources of charge.
  • Another participant references Gauss' Law, stating it connects the divergence of the electric field to charge density, but acknowledges this as a law rather than an explanation of why it holds.
  • A participant introduces a "bath tub" analogy to illustrate divergence, describing regions of positive divergence as sources and negative divergence as sinks, relating this to electric flux and charge distribution.
  • One participant discusses the conservation of energy in the context of an inverse-square field, using the example of a light bulb to explain how intensity relates to divergence and charge density.
  • Several participants reiterate the connection between divergence and Gauss' Law, emphasizing that divergence represents the net flux per unit volume and is proportional to charge density.
Participants generally agree on the relationship between divergence and Gauss' Law, but there remains uncertainty and varied interpretations regarding the physical meaning and implications of divergence in different contexts.
Some participants highlight the need for clearer definitions and assumptions regarding divergence and its physical interpretations, particularly in relation to charge density and fluid dynamics.
hanson
Hi all. I have difficulty in visualizing the concept of divergence of a vector field. While I have some clue in undertanding, in fluid mechanics, that the divergence of velocity represent the net flux of a point, but I find no clue why the divergence of an electric field measures the charge denity?
Can anyone tell me how to interpret the divergence of a vector field? Please kindly help.
That's essentially Gauss' Law [relating the field to the source]. It's a law of physics.
(It's somewhat akin to asking why the acceleration of an object is proportional to the net force on the object.)
Arguably, one could regard Gauss' Law as but one of the laws of electromagnetism...and find a deeper formulation of the laws where Gauss' Law arises as a particular aspect.
Have you seen the definition as a limit of flux per unit volume?
I would say that the divergence of E at a point tells you how much the field is "spreading out" or "emerging" (diverging?) from the neighborhood of that point. If the divergence is large, you must have some sources (charges) there.
If the divergence of a velocity field is zero, it means the fluid is incompressible.
This (and the subsections) might be useful:
http://www.math.gatech.edu/~carlen/2507/notes/vectorCalc/divcurlMean1.html
Consider what I like to call the "bath tub" analogy.
In this 2D analogy, regions of positive divergence are "taps" (sources), regions of negative divergence are sinks, water represents electric flux.
At any point where the divergence is zero (no sources or sinks), the water flowing in must equal the water flowing out correct? Hence if the divergence is zero, we can conclude that there is no net flux and thus there are no sources or sinks present at that point. Conversely, if the net flux is non-zero, that indicates that water is being added by a source (positive divergence) at that point, or being taken away (negative divergence) by a sink.
Of course, electromagnetically, the sources are positive charges and the sinks are negative charges. Gauss' Law however states that the charge density determines the divergence at a given point. How do we incorporate charge density into the "bath tub" analogy? By considering that a source or sink is not a point source (or sink), but rather distributed over space.
Keeping with the "bath tub" analogy, the divergence at a point is therefore dependent on the amount of water being added (or removed) at that point, which in turn is equal to the total amount of water added by the entire (distributed) source, divided by the surface area of which the source is distributed. This is essentially a crude expression of Gauss' Law in differential form.
Using our electrostatic analogue, this is equivalent to saying the divergence is equal to the total charge of a given distibuted charge, divided by the volume of the charge (i.e. the charge density), which is what Gauss' law says in differential form.
I hope that long winded spiel helped rather than hindered :smile:
Claude.
Thank you all.
Let me read through the replies carefully.
hanson said:
... but I find no clue why the divergence of an electric field measures the charge denity?
as other's pointed out, this has to do with Gauss's Law. it is a differential form of Gauss's Law.
Gauss's Law is applicable in 3-dimensional space for any inverse-square field. and, in 3-space, inverse-square fields are quite natural for any conserved physical quantity.
imagine a 100 watt ([itex]P[/itex]) light bulb radiating energy equally in all directions (omni-directional). we consider intensity of radiation to be the amount of power that falls on a unit area held perpendicular to the imaginary line connecting the source to that unit area. so intensity is watts per square meter. imagine that this light bulb is surrounded by a series of concentric spheres, all centered with that light bulb in the middle. since energy is conserved, all of this power radiating outward has to be the same whether it is the power escaping from one of the smaller spheres (where the intensity is higher, but the surface area of the sphere is less) or from one of the larger spheres.
for each sphere, the sum of the power crossing each little segment of surface area must add up to the total power. and, for a sphere, each little segment of surface area is perpedicular to the origin of the radiant power moving out and equidistant from the origin. the power that crosses a little segment of surface area is equal to the intensity, [itex]I[/itex], times the area of that little segment. being a sphere, all little areas add up to the total area and the intensity is the same for all of these little areas because of symmetry (they are all equidistant from the source at the origin).
so the total power, [itex]P[/itex], must be
[tex]P = (4 \pi r^2) \cdot I[/tex]
that total power moving from inside the sphere to outside is the same whether the sphere is a small one or a large one. then the intensity must be:
[tex]I = \frac{P}{4 \pi r^2}[/tex]
so the intensity must be an inverse-square field since energy and power are conserved and the area of a sphere is [itex]4 \pi r^2[/itex].
now, our understanding is that (static) electric field from a point charge (or a collection of them) is naturally inverse-square because we imagine such E-field as being proportional to some imagined "flux" density, called [itex]D[/itex]. imagine these lines of flux as proportional to the amount of charge emanating out from a point charge. since these lines of flux are a conserved quantity (no new lines of flux are created out of nothing or destroyed into nothing), then the density of these lines of flux (flux per unit area) must also be an inverse square field. integrating the flux density (or the E-field) over the whole surface area of the sphere is proportional to the charge at the origin. what about flux coming from other sources? well, when those flux lines cross from outside the sphere to the inside, that counts as negative and gets canceled by the same flux lines when they cross from inside back to outside. Gauss's Law also shows that even for sources not at the origin, but inside the sphere, when you count only the component of the flux density vector that is perpendicular to the surface when it crosses from inside to out, that all of this flux adds up to the charged contained inside.
now, divergence is this same thing except that now the containing volume is getting smaller and smaller to, in the limit, an infinitesimally small volume. so now, if you consider that, when you get this small, that charge is distributed evenly in the space and the amount of charge contained inside the sphere is proportional to the volume (charge density times volume). but even in this small volume, the net amount of flux moving from inside the volume to outside is still proportional to that charge (which is proportional to the volume). the divergence is the net amount of flux per unit volume moving from inside a differential amount of volume to outside of it and it is proportional to the charge per unit volume which is the charge density.
Thank you all.
I think a get a better understanding now.
Thanks!
17K
  • · Replies 17 ·
  • · Replies 17 ·
