| Thread Closed |
Mixture Component Problem |
Share Thread | Thread Tools |
| Feb8-07, 09:26 PM | #1 |
1. A mixture at T=300 K and P=100 kPa is made up of .1 oxygen, .2 carbon dioxide, and .7 Nitrogen. It is then heated to 300 kPa and 500 K. Find the mass of each component
I originally thought using PV=NRT, ideal gas but there doesn't seem to be enough givens. Can you also find the molar mass of the mixture by doing: .7(28)+.2(44)+.1(32), so then you can find the mass of the component when you find the number of moles N but I am having problems doing that |
| Feb9-07, 10:56 PM | #2 |
Yes, the question is incomplete. In addition, it's ambiguous, as it does not state whether .1, .2 and .7 are mass or molar (ie, volume) ratios (assuming they are ratios).
| Thread Closed |
| Thread Tools | |
Similar Threads for: Mixture Component Problem
| Differential Equation (mixture problem) | Calculus & Beyond Homework | 1 | ||
| Starting a Mixture problem | Calculus & Beyond Homework | 9 | ||
| Gas mixture problem! | Biology, Chemistry & Other Homework | 3 | ||
| Mixture Problem (differential equations) | Introductory Physics Homework | 9 | ||
| Homework help with mixture problem | Differential Equations | 1 | ||
