Dynamics - Airplane stopping on a runway
  • Thread starter Thread starter auburntigers_dy
    Airplane Dynamics
The problem involves an airplane with a mass of 5 Mg that touches down at a speed of 300 m/hr. The task is to calculate the distance required to reduce its speed to 150 km/hr after deploying a braking parachute, with drag varying as a function of velocity, modeled by the equation D=k*(v^2).
  • Participants discuss the application of Newton's second law and the integration of equations to find displacement. There are questions about the relevance of certain equations and how to handle the velocity dependency in the calculations.
Some participants have attempted to derive the drag constant 'k' and relate it to the acceleration of the airplane. There is ongoing exploration of how to proceed with the integration and what specific velocities to use in the calculations. Multiple interpretations of the problem are being discussed, with no explicit consensus reached yet.
There is mention of a calculated answer from a textbook, but participants express confusion regarding the steps to achieve that result, particularly in terms of expressing acceleration and displacement in relation to velocity.
auburntigers_dy
an airplane has a mass of 5Mg has a touchdown speed of 300m/hr. At which instant the braking parachute is deployed and the power shut off. If the total drag on the aircraft varies with velocity as shown in the accompanying graph, calculate the distance x along the runway required to reduce the speed to 150km/hr. approximate the variation of the drag by an equation D=k*(v^2). where 'k' is a constant.
integral of (vdv)=a* integrate ds
The constant 'k' was found to be 120,000 Newtons/(83m/s)^2
from the graph. Then, how to calculate the displacement is where the help is needed. The calculated answer from the back of the of the book is 201m. Any help on this problem would be appreciated.
thanks
I see no "attempt at a solution". Are you not even trying?
auburntigers_dy,
I don't think that the "relevant equation" you cited is all that relevant. Can you write down Newton's second law for this problem? That would be a good start.
tom mattson,
Newton's second law is f=m*a. ma=kv^2. therefore a=(kv^2)/m. This is where the relevant equation that i cited could be used, where the acceleration is calculated and velocity is given which then leaves you with the unknown term delta x. I am stuck on what velocity would i use to solve for this delta x.
dynamics
Hallsofivy,
i solved for k, the drag force is kv^2 which i equated it to Newton's second law Mass*acceleration. Then solving for acceleration resulted in k*v^2/(5000kg). then I integrated the relevant the relevant equation vdv=ads to solve for ds. The confusion lies in the calculated acceleration which is also expressed in terms of velocity which leaves stuck upon how to solve for displacement.
dynamics
Hallsofivy,
i solved for k, the drag force is kv^2 which i equated it to Newton's second law Mass*acceleration. Then solving for acceleration resulted in k*v^2/(5000kg). then I integrated the relevant equation vdv=ads to solve for ds. The confusion lies in the calculated acceleration which is also expressed in terms of velocity which leaves me stuck upon how to solve for displacement. everything is expressed in terms of velocity.
9K
