| Thread Closed |
What is the best way to integrate this?? |
Share Thread | Thread Tools |
| Feb10-07, 07:46 PM | #1 |
What is the best way to integrate -250*cost*sin^2t dt ??
I'm looking in my old calc book and it says to integrate by parts-is this the only way to do it? When I try this it makes the integral even more complicated than it was to begin with. |
| Feb10-07, 08:04 PM | #2 |
What are you choosing as u and dv?
| Feb10-07, 08:07 PM | #3 |
Try a u-substitution. The most obvious being u=sin(x)
| Feb10-07, 08:08 PM | #4 |
Okay so heres how I did it:
The general rule is Integral of udv = u*v - int(v*du) So i said that v = sin^2t dv/dt = 2sintcost du=costdt --> u=sint Integral = sin^3t - int (sin^2t*costdt) ?????????????????????????? |
| Feb10-07, 08:09 PM | #5 |
| Feb10-07, 08:10 PM | #6 |
This is really messy, are you absolutely sure the book said to use integration by parts because if the problem is exactly as you've posted it then there is a much simpler way. |
| Feb10-07, 08:11 PM | #7 |
| Feb10-07, 08:14 PM | #8 |
No it absolutely didnt say intgrate by parts...i'm in a higher level class and havent touched calc in 5 years and so i forget how to do this basic operation. I looked in my old freshman yr calc book and thats what it said to do. If you have a simpler way, i'm sure thats what we should do.
| Feb10-07, 08:17 PM | #9 |
We have to do line integrals and as a part of the g(x,y)dx, dy, ds..this was one of the problems i was having (actually performing the integral).
| Feb10-07, 08:17 PM | #10 |
| Feb10-07, 08:18 PM | #11 |
um. okay. well i'm not lying?? I mean i dont know how that it supposed to be constructive. do you have the name of the method, the easier way, that you would use?
| Feb10-07, 08:19 PM | #12 |
| Feb10-07, 08:21 PM | #13 |
Ooooh. got it, thanks. so when should i use the u substitution method vs integration by parts? the u sub worked out perfectly in this case...
| Feb10-07, 08:22 PM | #14 |
| Feb10-07, 09:05 PM | #15 |
Recognitions:
Another way to do it would be to use double angle formula (for cos) and then factor formulae to simplify, then just integrate. Not difficult either.
| Feb11-07, 11:30 AM | #16 |
You could use the double angle of sin. (sin(2t)=2sintcost) and substitut it .
Would be somethink like this: -250 S cos t sin 2t dt -250 S cos t 2sint cost dt -500 S (cos t)^2 sint dt Then u=cost du=-sint dt, then 500 S u^2 dt 500 (u^3)/3 substituting back u= cost 500 (cost)^3* 1 / 3 Wala, there is, no integration by parts is useless if you have the du on the integral. Just the double angle formula. -Link |
| Feb11-07, 11:34 AM | #17 |
You are the rule right but the dv/dt= -2 cos 2t, you just use the double angle formula. -link |
| Thread Closed |
| Thread Tools | |
Similar Threads for: What is the best way to integrate this??
| integrate | Calculus & Beyond Homework | 4 | ||
| How do you integrate this?? | General Math | 6 | ||
| Integrate ln(4+y^2)dy? | Calculus | 8 | ||
| How do I integrate this? | Calculus & Beyond Homework | 4 | ||
| how to integrate??? | Calculus & Beyond Homework | 5 | ||
