How do the forces on block B affect its motion?
  • Thread starter Thread starter Peach
    Friction
The problem involves two blocks, A and B, with given weights and a coefficient of kinetic friction. The objective is to determine the horizontal force required to drag block B at a constant speed while block A remains at rest. The discussion centers around the forces acting on both blocks and the interactions between them.
  • Participants discuss drawing free body diagrams (FBDs) for both blocks to identify forces, including weights, normal forces, and frictional forces. Questions arise regarding the nature and direction of the friction forces acting on block B, as well as the relationship between the normal forces on blocks A and B.
There is an ongoing exploration of the forces involved, with some participants providing clarifications about the normal and frictional forces. Multiple interpretations of the forces are being discussed, and participants are actively questioning their understanding of the setup.
Participants note the complexity of the interactions between the blocks and the need for clarity on the forces acting on each block. There is a recognition that the normal forces are different for each block, and the discussion includes the implications of these differences on the overall problem.
Peach
Block A in the figure View Figure weighs w_1 and block B weighs w_2. The coefficient of kinetic friction between all surfaces is u_k.
Find the magnitude of the horizontal force \vec{F} necessary to drag block B to the left at constant speed if A is held at rest (figure (b)).
F = ma
a = 0
I attempted by drawing two FBDs for A and B. I have for
B: w_2 downward, F_aonb downward, normal force upward, F to the left dragging, and fk_ground
A: w_1 downward, normal force upward, F_bona, and fk_ab
Then I solved for the normal force and I got n = (w_1+w_2)/2 and then I plugged it into the fk = ukn, but well wrong answer.
I have a few questions because I don't really understand the whole picture. There's two frictional forces acting on B right? From A and from the ground? Is this correct? Also, the normal force for both B and A...are they the same or are they different? They're different right?
F = ma
a = 0
B: w_2 downward, F_aonb downward, normal force upward, F to the left dragging, and fk_ground what about the magnitude and direction of the friction force from A on B ? [/color]
A: w_1 downward, normal force upward, F_bona, and fk_ab Specify the directions of the ones you have identified.[/color]
Then I solved for the normal force and I got n = (w_1+w_2)/2 and then I plugged it into the fk = ukn, but well wrong answer.how did you get this?[/color]
I have a few questions because I don't really understand the whole picture. There's two frictional forces acting on B right? From A and from the ground? Is this correct? correct[/color] Also, the normal force for both B and A...are they the same or are they different? They're different right?correct[color]
Draw the FBD's again and identify the forces on each block. The normal force on block A is the force upwards of B on A.
You left out the friction force of A on B. Note also: the force you call F_aonb downward is the normal force between A and B. A and B exert two forces on each other: a normal force and a friction force.
Seems like you are counting the normal force twice: F_bona is the normal force. And you left out the tension in the rope pulling on A. (You don't need to analyze the forces on A to solve this problem, but it's good exercise.)
I assume you mean the normal force between the ground and B. How did you solve for it? (Consider vertical forces only.)
Absolutely correct.
Yes. The normal force between A & B is different from the normal force between B & ground.
Okay, the friction force from A to B is going in the same direction as the friction force from the ground to B right? Because friction forces are always in the opposite direction from the acceleration and perpendicular to normal forces..? If that's not wrong, then this is what I'm getting:
n_gb: n_ab + w_2
F: fk_ab + fk_gb
Is this correct? Am I going in the right direction, no pun intended?
Edit: Oh! And n_ab is w_1 right? Because the normal force on A = n_bona = w_1? That's what I'm getting from my FBD of A...
n_gb: n_ab + w_2
F: fk_ab + fk_gb
Yes, this seems correct...
I got the answer. Many thanks for both the help. ^^
  • · Replies 33 ·
  • · Replies 23 ·
