Solving the Logistic Model: Find P(66) with P(0)=3
  • Thread starter Thread starter glid02
    Model
The discussion revolves around solving a population model described by a logistic equation. The original poster attempts to find the population at a specific time, given an initial condition.
  • Participants explore integration techniques and the separation of variables in the context of the logistic model. There are questions about the correct setup of the equation and the integration process. Some participants suggest clarifying the initial equation and correcting the integration steps.
The discussion is ongoing, with participants providing guidance on integration methods and addressing potential errors in the original poster's approach. There is a recognition of the need to separate variables correctly and to apply logarithmic properties in the integration process.
Participants note issues with accessing the original equation and the implications of initial conditions on the integration constant. There is also mention of confusion regarding the application of logarithmic identities in the solution process.
glid02
Here is the first question:
A population P obeys the logistic model. It satisfies the equation
https://webwork.math.uga.edu/webwork2_files/tmp/equations/11/02d0a645c053f1f6002d746c78143f1.png
Assume that P(0)=3. Find P(66)
First I multiplied both sides by dt and integrated, giving:
P=6/700Pt(7-P)+c
If P(0)=3 then c=3
P=6/700Pt(7-P)+3
Then I divided everything by P and had
1=6/700t(7/P-1)+3/P
Now to find P(66)
1=6/700*66(7/P-1)+3/P
1=396/700(7/P-1)+3/P
1=2772/700P-396/700+3/P
4872/700P=1096/700
P=4.445
That's not right, what am I missing?
Thanks.
Your first equation is not visible. Perhaps you could rewrite it?
You have to accept some sort of web certificate to view the equation. It seems to be located on some university's website. Heres the equation that I get:
[tex]\frac{dP}{dt} = \frac {6}{700}P(7-P)[/tex]
Ahh, ok, thanks for that, ranger. I must have clicked no automatically!
P=6/700Pt(7-P)+c
If P(0)=3 then c=3
P=6/700Pt(7-P)+3
1=6/700t(7/P-1)+3/P
Now to find P(66)
4872/700P=1096/700
P=4.445
Thanks.
You have this equation: [tex]\frac{dP}{dt} = \frac {6}{700}P(7-P)[/tex]. You cannot simply multiply by dt and integrate, since you have not integrated the terms including P wrt P! You must rearrange the equation to give: [tex]\int \frac{dP}{P(7-P)}=\int\frac{6}{700}dt +C[/tex]
Do you know how to solve this?
You did put +C accidentally right?
Yeah, I can solve that. Didn't think to separate variables for some retarded reason. Thanks for the help.
Yea, I guess I haven't really integrated anything yet, so strictly the constant doesn't appear until the next line!
You're welcome!
OK I lied, I'm still not getting the right answer.
dP/P(7-P)=6/700dt
1/7log(P)-1/7log(7-P)=6t/700+c
log(P)-log(7-P)=6t/100+c
Using e
P-7+P=e^(6t/100)+c
P=(e^(6t/100)+7)/2+c
P(0)=3 so c=-1
Subbing 66 for t, I get 28.729
Still not right, what am I doing wrong now?
Thanks again.
dP/P(7-P)=6/700dt
1/7log(P)-[/color]1/7log(7-P)=6t/700+c
log(P)- log(7-P)=6t/100+c
The - sign in red should be a +
Using e
P-7+P=e^(6t/100)+c
What you've done here is wrong. You must collect the logarithmic terms before you can take the exponential of both sides.
You lost me with the collecting. Can you give me another example?
Well, have you come across the general rule: log(a)+log(b)=log(ab) ?
If I had I'd forgotten it. I should be able to solve from here (again). Thanks again for helping.
