Finding the Centroid of a Shaded Area with y=sqrt(x) Curve: Step-by-Step Guide"
  • Thread starter Thread starter Bradracer18
    Centroid
The discussion focuses on finding the centroid of the shaded area under the curve defined by the equation y=sqrt(x) from the origin (0,0) to a point along the x-axis at length b. The user seeks guidance on determining the differential area element dA and the moment about the x-axis, represented as xdA. The correct approach involves integrating these elements from 0 to b and subsequently calculating the centroid using the formula for the centroid coordinates. The user is advised to utilize integration techniques to derive the necessary equations for dA and xdA.
  • Understanding of integral calculus, specifically definite integrals.
  • Familiarity with the concept of centroids in geometry.
  • Knowledge of differential area elements in calculus.
  • Ability to manipulate algebraic expressions involving square roots.
  • Study the method of finding centroids using integration techniques.
  • Learn how to derive differential area elements for curves.
  • Explore the application of definite integrals in calculating areas under curves.
  • Review examples of centroid calculations for various geometric shapes.
Students in calculus, geometry enthusiasts, and anyone looking to understand the application of integrals in finding centroids of shaded areas under curves.
Bradracer18
I need to locate the centroid of the shaded area, in my picture. The shaded area is under the line(in between the x-axis and the curve.)
The curve is y=sqrt(x) And stretches a length from the y axis(0,0), along the x axis, a length of b.
This is a new concept, so I'm not really familiar with how to do these. It will probably take some walking through, for me to understand it.
A = Int(dA)...not sure how to use integral, so will just use int.
X = int(xdA)
I'm not sure how to find dA. I think I need to take a slice(or maybe 2) of the curved area. I'm not sure how to come up with those equations.
Then, I think that I need to find xdA, which I'm also not sure how to come up with. I'm assuming it's something like y times dx. But again, I'm not sure how to come up with the equation for that. After that, I think I would just integrate both of those equations, from 0 to b, and then divide the X equation by the A equation. Is this the correct approach? If so, what equation should I use for dA and xdA? Any help would be greatly appreciated. Thank you.
  • · Replies 17 ·
22K
